Author Topic: 170 injectors  (Read 2042 times)
Offline percycars
170 injectors
« on: 10 August 2011, 17:34 »
I was looking at getting a GTD golf but i see that there is alot of probiems with the PD 170 injectors do they use the same injectors in this engine or have they changed them
Offline Snoopy
  • Moderator
  • Geoff.
Re: 170 injectors
« Reply #1 on: 10 August 2011, 17:43 »
The GTD mk6 uses a common rail injection (CR).
The older mk5 GT TDI use the VW Pump Duse Unit injector technology  (PD)
Different injection systems.
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline Keithuk
Re: 170 injectors
« Reply #2 on: 10 August 2011, 21:09 »
I believe they are different from the 140 TDI injectors?
Quote
From the factory the differences are quite comprehensive.
VNT1749VC turbo with improved impeller and inlet housing with more precise vane control
Top mounted to allow for DPF over 140 without
Improved water jacket around uprated Siemens pizeo injectors and exhaust ports
- these Siemens injectors are dying left and right though!
Ceramic glow plugs
CTC toothed belt sprocket on the camshaft - it's oval to reduce belt tensions
Improved head gasket to both strengthen head and improve combustion chamber
Valves recessed flat into head allowing removal of valve pockets in pistons, improving swirl and compression
Improved oil separation system in cam cover
Uprated "hotdog" style EGR cooler
Forged and lightened crank with 4 counterweights instead of 8
A balancer shaft in the Passat level cars
Swirl flaps in the inlet manifold, improving swirl and flow across the rev range
A new electric EGR valve
Sourced from the VW service training program 368
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline The Doc
  • E63s Estate - Vito Sport
Re: 170 injectors
« Reply #3 on: 11 August 2011, 07:37 »
In short no, they have changed them  :wink:
