Author Topic: RE: lost boost  (Read 3598 times)
Offline yourloveismydrug
RE: lost boost
« on: 10 August 2011, 01:13 »
downloaded a vcds lite and finally got a fault code
P1557-35-00  17965 charge pressure control . positive deviation
is this likely to be my  Valve for Boost Pressure Control (N75)??
I have not messed with any pipe work and it is fine now so cant see it being a split/loose pipe
Re: RE: lost boost
« Reply #1 on: 10 August 2011, 12:16 »
took it for a run this morning after clearing the fault code,  managed to get it to happen again ,
uphill , accelerating hard in third , changed to fourth and then limp mode .
stopped reset it and then couldn't get it to do it again .
how can I test the N72 valve , will have a look at the actuator this evening
Offline Rhyso
Re: RE: lost boost
« Reply #2 on: 10 August 2011, 12:22 »
Could be sticky turbo vanes  :sad:
Re: RE: lost boost
« Reply #3 on: 10 August 2011, 13:09 »
sort of hoping its not , already asked about anything I can do to clean while in sit
Offline Agreeable Slick
  • Unit
Re: RE: lost boost
« Reply #4 on: 10 August 2011, 13:27 »
Could be many things.
Boost pipes
Vacuum pipes
Boost Pipe clips
Vane mech
Guy I know had a similar problem and it was a pipe had been melted through as the grommit on it had moved and left it rubbing on the manifold.
Re: RE: lost boost
« Reply #5 on: 10 August 2011, 14:50 »
I will of course go through the simplest things first , vac pipes to and from the boost controller , ecu etc
then all the inetrcooler imlet pipes and so on .
she want siliconehoses now anyhoo
Offline old_n07
Re: RE: lost boost
« Reply #6 on: 11 August 2011, 10:41 »
Have a read through this thread, should give you some pointers.
Basically:
Check the vac pipes are connected and not split
Check the VNT actuator arm is moving freely
Check it holds vacuum - if it doesnt the diaphragm inside could be split
Check boost pipes and clips
Check the N75 valve is working - output test in vagcom - this will move the actuator
If all of the above are OK it is more than likely sticking VNT, so log the boost levels and see if you are getting overboost that is throwing the limp mode.
Neil
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
