Author Topic: what bhp will i get  (Read 2792 times)
Offline dubpound
what bhp will i get
« on: 09 August 2011, 19:38 »
i have a mk4 1.8t golf and am looking at getting a k04 along with a miltec cat back exhaust system forge dv and a pannle filter what bhp am i looking at once remaped at stage 2 if poss?
thanks :smiley:
Offline Dalo Harkin
Re: what bhp will i get
« Reply #1 on: 10 August 2011, 08:34 »
For a stage 2 you need additional things, car has to be in tip top condition, an uprated TIP, FMIC is beneficial etc
Offline dubpound
« Reply #2 on: 10 August 2011, 10:02 »
fogot about them but what bhp looking at stage 1 and stage 2 any 1 know
Offline Carbon-Chiptuning
  • Carbon Chiptuning
« Reply #3 on: 10 August 2011, 12:30 »
Hi Dubpound,
Whats your engine code???
Kind Regards,
Nick - Carbon
Carbon Chiptuning
Intelligent Solutions
mobile: 07825 215003
freefone: 08000 435 997
email: nick@carbonst.com
web: www.carbon-chiptuning.co.uk
Offline dubpound
« Reply #4 on: 10 August 2011, 14:12 »
aum
Offline MaXXeH
  • Golf MK5 GTI
« Reply #5 on: 10 August 2011, 15:38 »
260-270 i would say
Offline Sammie-GTI
« Reply #6 on: 10 August 2011, 16:48 »
id say about 250-60bhp
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #7 on: 11 August 2011, 07:56 »
I'd say 250-270 it depends a lot on the condition of the engine etc and the car on the day  :wink:
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #8 on: 11 August 2011, 22:46 »
With the mods the safe flow for your setup would only be around 220bhp max.
Limiting factor would be the down pipe and cat, they get stupid hot with just stage1 power, which means the engine had to run rich at the top end to stop thermal damage.
To get good power you will been more than a cat back milltek, 007p and air filter, with just these mods running 270bhp your going to melt parts, you will need a fmic and performance down pipe and sports cat / decat.
Stage1 aum ko3s power safe is 210bhp/230lbft 19psi peak and stage2 with supporting mods would be upto 240bhp/270lbft 23psi peak
Which ko4 are you looking at using?
001 or 02x?
What engine code are you looking at tuning? Aum with stock injectors and maf will flow 270bhp, but to make the most of the k04 hotside which can produce awesome torque it's a good idea to use the TT 380cc injectors.  If it's an AGU then the injectors and maf top out 240bhp As the map mag scale is only 673kg/hr so a vr6 maf and 310cc injectors would be needed.
Your best option is get the most from your current turbo, ie stage2 power with turbo back and fmic, then go ko4,  but going ko4 with out down pipe is going to be a waste of money.
« Last Edit: 11 August 2011, 22:55 by RTechUK »
 01455 617233
