Author Topic: lost boost  (Read 3289 times)
Offline yourloveismydrug
lost boost
« on: 09 August 2011, 18:07 »
2003 GT tdi 150 driving up the road and I put my foot down in 3rd gear and all was well until just after it started boosting and then it went flat.  No boost .  no lights on dash , no noise , no dramas ( other than the Mrs saying ' thought VWs were reliable') .
some black smoke was noted earlier from the exhaust , not loads but enough to be noticeable .  would suggest a leak in the boost system .
ideas , where to start
Offline Adam
Re: lost boost
« Reply #1 on: 09 August 2011, 18:09 »
It sounds like limp mode. Get it scanned for faults.
Down Hill From Here.
Re: lost boost
« Reply #2 on: 09 August 2011, 18:13 »
I canned it when I got home and nothing , not vagcom or vcds though
Offline Adam
Re: lost boost
« Reply #3 on: 09 August 2011, 18:25 »
If it was limp mode it would have stored a code. Check the boost piping and the vacuum piping on the bulkhead.
Re: lost boost
« Reply #4 on: 09 August 2011, 18:33 »
I check all the piping , got under the car and checked everything best I could .
ran all the diagnostics software I have , cant find my vcds disc  :angry:
took it for another run and its fine .
could I have a sticky turbo ?  would that lodge fault codes ..  what to do if it is , cleaner etc .
Re: lost boost
« Reply #5 on: 09 August 2011, 21:21 »
took it out for a drive , a brisk one and  no problems .  so as soon as I have a minute or two I will be going over all the piping thoroughly and having a look at the turbo etc
