Author Topic: Overheating  (Read 3223 times)
Offline Sam
  • Sam I am
Overheating
« on: 09 August 2011, 17:56 »
MK2 16VT is overheating in terms of water, oil gets high too but only hit 104deg max so not worried. I noticed the expansion tank has no water in and there was water sprayed around it, I took the lid off and it all came back through as if I had releised a load of pressure then bubbled down slowly and now has nothing in again with the lid off. Do I need a newcap or do I have bigger problems?
 :smiley:
Offline Jack3559
Re: Overheating
« Reply #1 on: 09 August 2011, 18:48 »
Clearly not the same thing, but my fiat used to do that and it was because the head gasket was going.
Offline bodga
  • F reg GTI 16v
Re: Overheating
« Reply #2 on: 09 August 2011, 19:02 »
Is the radiator fan kicking in and out? oil temp on mine reaches 110 deg when its in traffic. Is your cap blue?
Offline Sam
  • Sam I am
Re: Overheating
« Reply #3 on: 09 August 2011, 19:07 »
Cap is blue and the rad fan doesnt seem to kick in, I noticed that but the fan not kicking in shouldnt cause so much chaos
Offline raferackstraw
Re: Overheating
« Reply #4 on: 09 August 2011, 19:09 »
have you bled the system properly
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline Sam
  • Sam I am
Re: Overheating
« Reply #5 on: 09 August 2011, 19:13 »
You think this should be first call? To bleed the system and start again?
Offline bodga
  • F reg GTI 16v
Re: Overheating
« Reply #6 on: 09 August 2011, 19:14 »
Yup, the water will start to boil and spit out of your cap. short the 2 wires together on the therm switch (as your looking down at your rad there is a sensor bottom right, screwed in to the rad) If the fan cuts in its that thats fooked
Offline Sam
  • Sam I am
Re: Overheating
« Reply #7 on: 09 August 2011, 19:15 »
Car idleing or not?
Offline bodga
  • F reg GTI 16v
Re: Overheating
« Reply #8 on: 09 August 2011, 19:18 »
start it up yes, but when i turn mine off the fan continues to run sometimes when it been hot
Offline Sam
  • Sam I am
Re: Overheating
« Reply #9 on: 09 August 2011, 19:19 »
Yer mine does that, when It can be arsed. Will check it now  :smiley:
