Author Topic: Question for the PC Gamers  (Read 8851 times)
Offline Jimp
« on: 09 August 2011, 11:50 »
I'm building a new rig at the moment and need a hand with processors. I'm looking at Intel i3 and i5 processors and wondering, is there a point in paying more for a quad core i5 when the dual core i3s have hyper threading? Would there be a difference in real-world performance? Let's assume I'm usually running a game (SC2, WoW, TF2, etc), Teamspeak, Winamp, some messenger program and maybe Firfox with plenty of ram.
Not low enough mk5
Not on the road enough mk3
Offline AlexMozza
Re: Question for the PC Gamers
« Reply #1 on: 09 August 2011, 12:00 »
Yes, go for an i5 sandy bridge :)
Lots of performace and scope for overclocking etc and they are not to expencive either,
http://www.scan.co.uk/products/intel-core-i5-2500-s1155-sandy-bridge-quad-core-33ghz-gpu-850mhz-6mb-cache-95w-retail
 :cool:
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
Offline Jimp
« Reply #2 on: 09 August 2011, 12:16 »
Unfortunately that one is too expensive  :cry: The budget for the build is tight so I'm wondering is the extra €50+ for an i5 processor worthwhile over an i3 like this one.
« Last Edit: 09 August 2011, 12:22 by Jimp »
Not low enough mk5
Offline Ridg
  • TDI - Soot Happens!
« Reply #3 on: 09 August 2011, 12:35 »
 :cool:
+1
best value chip you can get at the moment
the i3 is real entry level, it should cope with the games you've mentioned, HT is much better than it was on the P4 chips, but some games and apps still struggle on it in comparison to actually having 4 physical cores.
If you're on a budget then you'll probably want to consider an AMD system, AMD can't touch intel at the moment, but they are pretty good value; personally I'd pay the extra €50 as it's going to significantly increase the life of the system.
Offline AlexMozza
« Reply #4 on: 09 August 2011, 15:59 »
I went down the AMD route :)
You will get better bang for your buck with an AMD, Motherboards are cheeper too but if your on a budget any cheap processor will be out of date within a year, as said spend a little more and you have several years out of it  :cool:
« Last Edit: 09 August 2011, 16:02 by AlexMozza »
2001 Satria GTi
Formula 3 Mechanic
Offline Evoss
« Reply #5 on: 09 August 2011, 16:11 »
What is your budget and ill spec you a system.
Offline Jimp
« Reply #6 on: 09 August 2011, 17:45 »
Budget is an absolute max of €600, preferably closer to €500.
4 gigs of Corsair ram comes in at a very reasonable price, as does a hard drive and case+psu. I was looking at an Asus ATX motherboard since they quite good and there's room for upgrading to a LGA 1155 socket i7 when funds allow in a few months time. The gfx card was going to be an Asus GTS 450. The final €100->€200 is for the processor.
Not low enough mk5
Offline Evoss
« Reply #7 on: 09 August 2011, 18:56 »
« Last Edit: 09 August 2011, 19:02 by Evoss »
Offline AlexMozza
« Reply #8 on: 09 August 2011, 19:46 »
Scan.co.uk is cheaper on almost everything :D
2001 Satria GTi
Formula 3 Mechanic
Offline Jimp
« Reply #9 on: 09 August 2011, 20:02 »
Thanks for that Evoss :afro: The ram, case, psu and processor are the exact ones I had looked at  :grin: Only differences are the gfx card and this motherboard:
ASUS_P8P67_LE_B3_Revision_Motherboard.
Apart from the the extra cooling technology on that MSI gfx card is there a particular reason you chose it?
Not low enough mk5
