Author Topic: mk2 16v running issue  (Read 1610 times)
Offline Low rider
« on: 08 August 2011, 20:04 »
rite here i go again  the car ticks over spot on  changed both pumps  gt the under nieth pump from a scrap yard runs kinda ok  amd jst starts jerkin and coughin and miss fireing and then cuts out bt u turn it off and bc on its ok then does it again
pls help or bye bye gti  :sad:  :sad:
Offline mk2bal
Re: mk2 16v running issue
« Reply #1 on: 08 August 2011, 21:28 »
Is it definitely a fuelling issue? Have you pulled + tested all the injectors? Have you proved good spark on all plugs? Have you tested the compression and checked the cam to crank timing, as well as inter cam timing? Do any wires or senders look grotty? Have you tested all 3 cylinder head sensors using the temp gauge if you haven't a meter? Have you got a strobe timing light so you can check the dizzy is set correct, and advancing properly? These are the fundamentals in making a 16v run good. Fuel pressure test kit (if you can beg, borrow or steal one) would be good as well to prove pumps, accumulator, wur etc.. Not meaning to throw loads at you but it pays to know all the above + more is all working tip top. You should also know the state of things like the thermo time switch, cold start injector, throttle (inc micro switch) and isv, as they all need to function correctly as well for good running, though in your case it doesn't seem to be a startup/idle problem so they're prob ok. Get to know your 16v buddy, don't sell it. Then you can reap the fruits..
Offline Low rider
« Reply #2 on: 08 August 2011, 21:51 »
Jst  remembered summat will only rev to six
Offline bodga
  • F reg GTI 16v
« Reply #3 on: 08 August 2011, 21:57 »
Air leak from meter head to throttle body?
what happens when it gets to six? dies or like rev limits?
Offline Low rider
« Reply #4 on: 08 August 2011, 22:36 »
Like it limits  :sad:
Offline Mew
« Reply #5 on: 08 August 2011, 22:46 »
Have you checked the timing?
Offline Low rider
« Reply #6 on: 08 August 2011, 22:51 »
Was fine till I changed underneath pump and wish side cam or dizzy timing
Offline Low rider
« Reply #7 on: 10 August 2011, 13:43 »
It's like the fuel is cuttin out pumpin  after a while bt I turn the ignition off and on it will run fine and then do the same  :(
