Author Topic: Freeing up an 8v GTI mk3?  (Read 4296 times)
Offline tsr_adi
« on: 07 August 2011, 18:38 »
OK so I've bought a mk3 8v GTI, and I'm well aware they're a bit underpowered! In the past I've fitted a decat to an Ibiza GTI with this engine and it did help reducing the engines nasty mid range flat spot, but I'm wondering if theres anything else I can do without breaking the bank to free it up a bit? Its been sat for a while so a good service is in order as well. I've heard of people putting mk2 digifant cams into them as they're not so eco-minded, will this help also?
Re: Freeing up an 8v GTI mk3?
« Reply #1 on: 07 August 2011, 20:51 »
Yep mk2 digi cam, panel filter and cold air feed.
Offline tsr_adi
« Reply #2 on: 07 August 2011, 21:32 »
What kind of gains should I expect from the above plus a de-cat? And will it pull strongly through the revs like a mk2 digi would?
« Reply #3 on: 07 August 2011, 23:44 »
5bhp to 10bhp and yes will help its response and how it feels
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 08 August 2011, 00:39 »
is that the AGG engine code?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline tsr_adi
« Reply #5 on: 08 August 2011, 06:15 »
I believe it is yea, well its a 94 M plate so I assume so
« Reply #6 on: 08 August 2011, 12:39 »
Being an early one it will / may be a 2e, AGG was 1996 onwards :smiley:
Offline tsr_adi
« Reply #7 on: 08 August 2011, 13:52 »
How can I identify a 2e from an AGG? And whats the difference?
« Reply #8 on: 08 August 2011, 14:14 »
Early lump is better, post a picture or check the logbook
Offline sharki786
  • GOT BOOST??
« Last Edit: 08 August 2011, 15:35 by sharki786 »
*****MK4 GTI T*****
