Author Topic: Three sensors on right side of engine.  (Read 1184 times)
Offline Lee Watson
« on: 14 April 2005, 14:12 »
I have a MK2 GTI 16v 1990 golf there are three sensors on side of the engine near the warm-up-regulator.
Can anyone tell me what the lowest one is for and if I unplug it when the engine is running hot whether it should do anything noticeable to the engine? Because the other two seem to make a difference.
Offline Gambit
Re: Three sensors on right side of engine.
« Reply #1 on: 14 April 2005, 14:53 »
they are all temperature sensors and they all have the same sensor in them, so they can be swapped around if need be. 2 go into the water jacket and 1 goes into the block.
but there is no correct way as to what wire goes where, so dont worry about swapping over & gettin mixed up etc
its the colour of the wires you need to know about
Red/Yellow - this used by your dash temp gauge
Red/Green - this used by the ISV/Cold Start
Blue/White - this used by the ECU
Offline Lee Watson
« Reply #2 on: 14 April 2005, 15:10 »
Cheers most helpful.. :smiley: :smiley: :smiley:
