Author Topic: exact size?  (Read 618 times)
Offline stainesy
exact size?
« on: 02 August 2011, 19:04 »
am going to buy an new middle strait bit of pipe that goes between cat and middle box wich will be 16v/vr6 size.
am just going to buy a bit of stainless pipe it that size.
anybody no the exact diameter and length so i can order it online?
Offline garfayliu
Re: exact size?
« Reply #1 on: 02 August 2011, 20:41 »
Hi, can't answer your question completely, but I know the OD (outer diameter) of the pipe from the CAT is 55mm (2.16") and you'll need a pipe with 57mm (2.25") inner diameter to go over the CAT pipe. Not sure of length, but you can get longer than needed and cut to length.
