Golf mk2
MPG sensor
Topic: MPG sensor (Read 994 times)
VWDino
GTI forum regular
MkII 1.6 Driver. GTi cam, K&N .....
MPG sensor
14 April 2005, 12:31 »
Hi,
Just trying to connect up the MPG hose for the MFA I have installed in my Driver. Could someone give me a clue which pipe I tap into? Also, will any sort of tubing that fits the connections do or does it have to be a certain diameter exactly etc for it to work correctly. At the moment I have it hooked up but it gives me silly readings. Starts from .1 and rises to 99.9 after about a min of driving. Think I got something wrong, unless my carb is the most efficient in the worldÂÂÂ
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: MPG sensor
15 April 2005, 14:24 »
I hooked it up using a vac tube 'Y' splitter from a 2e2 Golf in my scrappy. I connected it to the thin pipe that goes infront of the carb, the one that plugs into the chunky pipe between the inlet and brake servo.
Golf mk2
MPG sensor
