Author Topic: door insulation material  (Read 1293 times)
Offline nightroamer
  • Mk3 16v
« on: 02 August 2011, 05:35 »
Hi guys,
Had my door cards off to fit new speakers and found all have damaged or missing door insulation.
Also half the clips are fubar.
Where can I get both items, I know without them the cards rattle.
Also see wanted section as I need a new rear offside  door card lol
Offline javalin
Re: door insulation material
« Reply #1 on: 02 August 2011, 15:04 »
just done this.  Get the black foamy plastic stuff from VW - £5 or so a door.  Also get the clips from them, as the ebay ones I got were too small.   Door vapour barrier is part 17 on the front door pic - cut to size.  I used greenhouse tape to secure it.
You'll want 8 or 10 of part 14 - 1H0 868 243 B for the rear door, or similar for a front door.
rear:
from - http://www.wagenstad.com/index.php?modid=188&page=8-867-40
front:
http://www.wagenstad.com/index.php?modid=188&page=8-867-00
Also might we worth looking at recent posts on my blog - http://javalins.wordpress.com
oh - I have a good condition rear offside door card (98 GTI), a few subtle breaks where it was broken open to get to a seized lock, but the damage is quite well hidden.  Otherwise in VGC. PM me if you are interested.
James
« Last Edit: 02 August 2011, 15:08 by javalin »
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline nightroamer
  • Mk3 16v
« Reply #2 on: 03 August 2011, 09:50 »
rear:
front:
James
cheers james, off to VW me thinks....
Offline javalin
« Reply #3 on: 04 August 2011, 11:40 »
oh, thoughts whilst I remember:
-> When you cut the insulation to size, make sure you cut it so it fits inside the door card.
-> Easiest way to re-install is to put both parts of the clips on the door card, make sure your insulation is fitted correctly and then put the door-opening-handle through the door-card, attach the pull bar for it and simply push the door card home.  Make sure the cables are in the correct places first.
->  Test fit a few times without the clips attached to the card!
James
