Author Topic: Diesel particle filter... Advice please  (Read 1919 times)
Offline walchy01
« on: 01 August 2011, 20:25 »
Hi guys
Trying to help a mate out here, he has the engine management light on and has had the car on the fault reader machine which tells him it is the filter named above, it comes in at a cool £1500... :sick:
Is there any other way around this, he has been told to re map it ???
Any advice/help much appreciated...
Walchy
Offline Rhyso
Re: Diesel particle filter... Advice please
« Reply #1 on: 01 August 2011, 20:40 »
You can fit a delete pipe.  You will then need a remap to map out the regeneration cycles of the DPF as its no longer there
Prices vary but its considerably cheaper than a new DPF pipe.  Upside is more MPG and over 200bhp if done properly  :evil:
Offline stevieC
« Reply #2 on: 01 August 2011, 20:48 »
yeh as rhyso says,dpf bypass pipe,dpf delete software & a engine remap is the best way around this.Speak 2 Doc his tunning co. do this work.
Gtd 3dr candy white,charleston shadows
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #3 on: 01 August 2011, 20:53 »
Hi guys
Walchy
We look after a fleet of vauxhall Cdti taxi which are all running Dpf and all have issues with the blocking, in the vauxhall they are easy to remove and we blast them out with 400psi of compressed air, this tends to sort them for 12months.  I have not tried it yet on a vag dpf. The person in the know when it comes to dpf is The Doc.
 01455 617233
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #4 on: 01 August 2011, 21:58 »
Hi,
We can remove your problem - please call me in the morning and we'll go through your options  :wink:
Offline walchy01
« Reply #5 on: 02 August 2011, 19:43 »
Thanks guys I have passed the details on to my mate...
Thanks again...
