Author Topic: getting an 8v to rev faster  (Read 7576 times)
Offline Len
Re: getting an 8v to rev faster
« Reply #10 on: 01 August 2011, 13:25 »
Absolutely no point! The peak power is way below the redline anyway.
For instance my 16v revs to 7000 but the peak power is aroun 6000.
Revs do not make power.
www.sas.org.uk
www.the-ace.org.uk
Offline SoundillusioN
« Reply #11 on: 01 August 2011, 13:28 »
To make it rev faster when on the move or in English, accelerate faster you need more power, simples.
« Reply #12 on: 01 August 2011, 13:28 »
Lack of torque will not be helping. :rolleyes:
Offline sharki786
  • GOT BOOST??
« Reply #13 on: 01 August 2011, 13:31 »
He has same engine in his LCR as what i have in my golf
its night and day difference between his engine and how it revs and yours
thats what my cousine said, his comparing his cupra to my 8v, and my cousine has a 16v mk3 and says since i have had the flywheel fitted it has made a BIG diffrence.
& as soundillusion says need more power, which is of course true.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline javalin
« Reply #14 on: 01 August 2011, 13:55 »
lighter internals increase rate of rpm change I believe, but easier and cheaper to buy a new car I suspect.
Things like having a 16v engine with 16 smaller springs rather than 8 big springs, lighter crank/cam, etc.  Modern moves to electric power steering, load-sensative alternators etc, all reduce load on the engine and help.
J
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
« Reply #15 on: 01 August 2011, 14:04 »
Well there's probably nothing wrong with your car and someone who has a much quicker car is just stating facts rather than pointing out a problem....  Sadly it is what it is, you could spend lots of money and get a few more horses out of it but for that money you could get a cheap transplant, probably.
Offline sharki786
  • GOT BOOST??
« Reply #16 on: 01 August 2011, 19:10 »
new transplant on the book waiting for more funds :lipsrsealed:
*****MK4 GTI T*****
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #17 on: 01 August 2011, 19:13 »
you could do a 20VT swap fro a decent price if you choose the 150bhp lump out of something like a mk4 GTI, With a remap you would be looking at around 190 hp
or even cheaper u could wack a VR lump under your hood..
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline sharki786
  • GOT BOOST??
« Reply #18 on: 01 August 2011, 19:39 »
i have orgasms when i hear a vr sound AAAAAh :smug:
*****MK4 GTI T*****
Offline dennis10
« Reply #19 on: 01 August 2011, 21:46 »
To get it to rev faster, you could lighten the flywheel and Crank pulley.
This made a noticeable difference on my 16v, cost to effect it is probably the best thing you could do, it isnt expensive and you will notice it pick up much quicker
