Author Topic: oil pressure light keeps coming on saying stop engine "check oil pressure"  (Read 3305 times)
Offline Seanl
Jet washed the engine? You really think I would jet wash the bottom of an engine?  :laugh:
Anyways, After a flush, sh!te oil run through,  new oil, pipe cleaned and a new oil pressure sensor it's as good as new.......
I never used to use Engine flush... but running some cheap oil through it for an hour after brings out more crap... worth another £6
Yeah sorry about that.  :embarassed: You never know with some very inexperienced youngster about though.  :rolleyes:
Offline Dalo Harkin
Just wanted to say aswell incase anyone does this, when you look at the 20 sump bolts they take a 5mm hex key I think it is, but ALSO you can get a 10mm socket on the OUTSIDE.....
I discovered this after I had tried to remove them all with the hex and the last 2 were rounded  :angry:
