Author Topic: Broke my clutch pedal  (Read 944 times)
Offline kicklikeamule
« on: 01 August 2011, 00:48 »
Luckily, I was parked up at the time. Pressed the clutch pedal to the floor and heard something crack in the footwell  :shocked:
The pedal stayed down flat in the footwell. When I jiggled the pedal a bit side to side, a small (1cm) piece of black metal and an inch-long, oblong white plastic piece fell down into the footwell. The pedal came back up, but stayed down again when pressed. Like the spring mechanism had gone.
The breakdown chap said he'd seen this happen a few times on older Mk4's. Mine's a 2001. I'll see what the garage say the damage is tomorrow  :cry:
Offline dam088888
Re: Broke my clutch pedal
« Reply #1 on: 01 August 2011, 08:57 »
O just changed my clutch pedal as the slave cylinder had gone so easyer to chenge whole lot but nothing wrong with pedal you can have it if you pay postage
2000 agu 1.8t lowered 55mm,cream mirrors and wheels,stage 1 map, forge 007p,
Offline leeabbie555
« Reply #2 on: 01 August 2011, 09:00 »
Happened to mine a while back, got pedal from vw about £30 plus fitting so not too bad, think mine was £90 all in
Golf GTI T (agu)
Offline Simon_1.8T
« Reply #3 on: 01 August 2011, 15:30 »
Happened to me a couple of weeks ago. Had mine welded.
Some good info here. http://uk-mkivs.net/forums/t/18012.aspx
