Author Topic: is wax oil suitable for......  (Read 4978 times)
Offline jmsheahan
Re: is wax oil suitable for......
« Reply #20 on: 02 August 2011, 12:46 »
POR15 is great but a real PITA to prep for. Also £££ and once the tin is open you have to use it.
You are going to want 4941 for the underside and 3125 for the box sections although I have to say I prefer applying the Bilthamber dynax cavity wax. Make sure you get a long extension spray tube to reach right down the sills etc.
nige_s
« Reply #21 on: 02 August 2011, 12:58 »
So what dinitrol products do i want to buy then?
Usually these, covers most jobs on the car.
http://www.rust.co.uk/popup.cfm?p_i=509094&p_n=509094
http://www.rust.co.uk/popup.cfm?p_i=405069&p_n=405069
http://www.rust.co.uk/popup.cfm?p_i=405024&p_n=405024
I like to use the underbody (4941) wax on the surfaces, I find with waxoyl it tens to dry up and crack, this stuff doesn't and kind of self heals.
With POR 15 unless the surface is perfect it peels off after a year or so.
« Last Edit: 02 August 2011, 13:01 by nige_s »
Offline AudiA8Quattro
« Reply #22 on: 02 August 2011, 13:30 »
Nice one, i'll look into it  :smiley:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #23 on: 02 August 2011, 14:07 »
It says they do 1lt tins would these be better ?? also how many cans would be needed to do all underside ??
nige_s
« Reply #24 on: 02 August 2011, 14:30 »
I did all the arches on my 911 with 3 cans and have some left for touching up, must have some coverage as the inner arches are quite large and exposed so a lot of surface area.  If you are just doing one car I'd buy aerosols as it would be easier and wouldn't cost much more compared to the convenience.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #25 on: 02 August 2011, 14:37 »
Yer i recon about 8-9 cans then ??
nige_s
« Reply #26 on: 02 August 2011, 14:48 »
Sounds plenty to me, might be worth looking at those kits though.
http://www.rust.co.uk/dinitrol-products.cfm
