Author Topic: is wax oil suitable for......  (Read 4986 times)
Offline tech1889
  • Mk2 GTI FTW !!
Re: is wax oil suitable for......
« Reply #10 on: 01 August 2011, 11:42 »
where you buy above ? and do they do a brush on ?
Offline jmsheahan
nige_s
« Reply #12 on: 01 August 2011, 16:31 »
Epoxy mastic is one of the best things you can paint on the underside of your car.  Follow it up by a Dinitrol product.
http://www.rust.co.uk/epoxy-mastic.cfm
The £25 starter pack goes a very long way.
Forget Waxoyl and Hammerite it's sh*te
Offline rich1977
« Reply #13 on: 01 August 2011, 17:27 »
anyway how the feck do I clean the stuff off then lol, tried white spirit and a rag also a pressure washed it and still not shifting
Www.Internet-ink.co.uk voucher code RL15 for 15% off all pens,toners and ink cartridges including cannon Epsom dell and hp.
Offline andynorfolk
  • if at first you don't succeed, get a bigger hammer
« Reply #14 on: 01 August 2011, 17:31 »
if it's wax... heat it then remove it  :rolleyes:
Offline rich1977
« Reply #15 on: 01 August 2011, 18:47 »
tried that aswell with the hot air gun and its not melting, it apears to have just seaped into the vw underseal and dried, think im just going to have to leave it on
Offline andynorfolk
« Reply #16 on: 01 August 2011, 19:00 »
if it's not melting then it should be fine near the exhaust anyway  :smiley:
Offline AudiA8Quattro
« Reply #17 on: 02 August 2011, 12:24 »
Is Dinitrol really that much better than hammerite products?
nige_s
« Reply #18 on: 02 August 2011, 12:39 »
I've always found Waxoyl products difficult to apply and almost always need an annual 're-coat'.  Hammerite paints sucks on anything that is exposed on the underside.  I've used POR 15 paints which is much better than Hammerite but still doesn't last long.  Now using Epoxy mastic on the underside and as base on any repair work and it takes some beating.
Dinitrol chassis and cavity wax products always apply better and last much longer than Waxoyl in my experience.
« Reply #19 on: 02 August 2011, 12:42 »
So what dinitrol products do i want to buy then?
