Author Topic: Ignition coil photo added  (Read 3462 times)
Offline walchy01
« on: 29 July 2011, 21:06 »
Hi there
Picked up a new coil this afternoon but when I put it against the original that is fitted now it's about a 1/3 of the size, is this correct? also it has the king lead plug point, and a + and a - connector points, but again my current plastic fittings  push onto spade connectors( I think) will not fit to my new coil, do I need to change/modify the connectors or I have got something wrong here???
Hope u can understand my explanation :grin:...
Thanks very much
Walchy
« Last Edit: 02 August 2011, 14:04 by walchy01 »
Re: Ignition coil
« Reply #1 on: 29 July 2011, 23:53 »
Sounds like you have been supplied the wrong one.
What car have you got.
« Last Edit: 30 July 2011, 09:00 by Wayne »
Offline The Mighty Elvi
  • I'm better than you today.
Re: Ignition coil
« Reply #2 on: 30 July 2011, 00:33 »
Sounds like the wrong one.
Good call Wayne, glad you could help.
What car (engine)  have you got and where did you get the coil from?  Then we can deduce your problem.
Offline walchy01
Re: Ignition coil
« Reply #3 on: 01 August 2011, 14:21 »
Hi guys
It's a 16v, it was bought from ECP..
Offline SoundillusioN
Re: Ignition coil
« Reply #4 on: 01 August 2011, 14:33 »
Hi there
Thanks very much
Walchy
From the description of your new coil it sounds like you have one for a polo!?
To be honest I'm not sure it's worth trying to figure it all out, I would contact ECP and just tell them you have the wrong one and get it replaced.
Re: Ignition coil
« Reply #5 on: 01 August 2011, 16:31 »
Hi guys
Yep sounds like a Polo or early 8v one you have been supplied.
Offline walchy01
Re: Ignition coil
« Reply #6 on: 01 August 2011, 20:10 »
Right a couple of pictures to help solve my problem...
Thanks
Walchy
Offline walchy01
Re: Ignition coil photo added
« Reply #7 on: 02 August 2011, 19:35 »
Anyone confirm this is the wrong one, then I can take it back tomorrow :embarassed:
Thanks
Offline weazgti
« Reply #8 on: 02 August 2011, 21:06 »
Looks like a mk3 one
« Reply #9 on: 02 August 2011, 21:25 »
Yep it does :afro:
