Author Topic: Cruise control drops out  (Read 2136 times)
Offline Where-too
« on: 28 July 2011, 11:06 »
Hi,
Recently the cruise control on my mk5 DSG has begun dropping out at random moments. Following this it can not be switched on again and the absence of the light on the dash reflects this. The only way to get it back is by switching the ignition off and on again. I've heard a rumour that it might be the switch on the stalk that is at fault, however it seems strange that the ignition can reset the cruise if this is the case.
Any ideas? If it is the switch, is it a DIY job, or will I need to take it to a garage?
Thanks for your help.  :smiley:
Offline Brush57
Re: Cruise control drops out
« Reply #1 on: 28 July 2011, 17:58 »
Mine was doing the same had to get new stalk fitted and that cured the problem, cruise has worked no problem ever sence hope this helps
2012 Black Edition 35
Offline Where-too
« Reply #2 on: 28 July 2011, 18:16 »
Thanks Brush57.
Sounds like that could be the problem then. Hopefully I can fix it myself! Well in sure I can take it apart anyway. What follows after that could be interesting!  :undecided: !
Offline black-magic
« Reply #3 on: 30 July 2011, 01:26 »
I have exactly same issue with my cruise.   :sad: Its been like it for ages. IE Sometime it wont come on. Others time you can turn on / off say 4 / 5 times then it will stay off untill you turn off. I do find if I use it if the green light is on it will last the journey.
If anyone else has hand this and fixed then let us know.
Offline sprout99
« Reply #4 on: 30 July 2011, 10:49 »
you have a switch on clutch and brake pedals too.
brake one would cause brake light probs - your lights work ok?
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline _Adam_
« Reply #5 on: 01 August 2011, 09:13 »
i want cruise control  :sad: lol
Offline sprout99
« Reply #6 on: 01 August 2011, 09:49 »
easy to retrofit - stalk is £65 ish from stealer
Oak green mk2
V50 D5 Sportwagon
Offline gremlin848
  • golf mk 8 gti and luv it to bits kings red all opp
« Reply #7 on: 02 August 2011, 17:49 »
mine sometimes does not turn on only noticed it this week and the more i try it the more pi55ed of i am
Offline gremlin848
« Reply #8 on: 02 August 2011, 17:51 »
at 65 quid i might have to revert to the old right foot to keep the same speed like i used to in my mk 3 gti
