Golf mk2
Abs on mk2
Topic: Abs on mk2 (Read 3470 times)
Dave_IOW
Forum addict
Abs on mk2
27 July 2011, 19:33 »
Ok, so trying to help out a mate, he's got a mk2 16v engine and has fitted a abs pump from a passat b3, question is, how would I bleed the pump with vagcom?
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
tech1889
Serious forum addict
Mk2 GTI FTW !!
Re: Abs on mk2
27 July 2011, 19:47 »
why cant he man up and learn to feather the brakes
Mk4 Golf GTI anniversary and mk6 golf tdi
Dave_IOW
Forum addict
Re: Abs on mk2
27 July 2011, 19:56 »
Tech
seriously, any ideas
tech1889
Mk2 GTI FTW !!
Re: Abs on mk2
27 July 2011, 20:13 »
Quick google got me this
http://www.ross-tech.com/vag-com/cars/absbleeding.html
Dave_IOW
Forum addict
Re: Abs on mk2
27 July 2011, 20:37 »
Yeah seen that mate, just vagcom won't recognise properly the abs. It's got a b3 unit and abs ecu(?) and comes up ABS under bag number, just won't do anything after that..
Wayne
Sir Postalot
Re: Abs on mk2
27 July 2011, 23:54 »
Will it not bleed out with a pressure bleeder.
Dave_IOW
Forum addict
Re: Abs on mk2
Reply #6 on:
28 July 2011, 07:32 »
Tbh Wayne I have no idea, its just only done my mk4 one through vagcom and pressumed this would be similar? Will pressure bleed work on an abs unit then?
AudiA8Quattro
Forum addict
Re: Abs on mk2
Reply #7 on:
30 July 2011, 16:58 »
I've only ever used a pressure bleeder, never used VAG com.
Dave_IOW
Forum addict
Re: Abs on mk2
Reply #8 on:
30 July 2011, 18:27 »
even to do the ABS pump?
Mike671
Re: Abs on mk2
Reply #9 on:
31 July 2011, 23:23 »
Dave at work we only use pressure bleeder (2bar vas one) only need to operate the pump if it's completely dry which I would think yours is not. You should be able to prime pump through vag com or vcds if not some you can power up thr abs pump manually by puttin 12v to it HTH
Esplanade V.W Audi Mercedes And Smart Tech
Golf mk2
Abs on mk2
