Author Topic: Idling problem  (Read 868 times)
Offline LouisCyphre
Idling problem
« on: 27 July 2011, 19:13 »
Hey guys, being my first post here i hope this comes out right   :cool:
I have a slight idling problem with my Mk3 1.4L, 1996
It runs just fine while cold, but as soon as it has warmed up the RPM starts hunting up and down 500-1000RPM and occasionally it dies on me, rather annoying when the lights turn green.... :sad:
i am suspecting some kind of a vacuum or temp sensor problem?
It would be great to get advice on what i should try first.
Thanks!
Offline trog_nfs
Re: Idling problem
« Reply #1 on: 27 July 2011, 19:16 »
I'd say vacuum leak. Check all your breathers for splits or if they're perished.
Offline dansmk3
  • FULL TIME JUNGLIST
Re: Idling problem
« Reply #2 on: 27 July 2011, 19:57 »
what about ecu temp sensor?
Offline LouisCyphre
Re: Idling problem
« Reply #3 on: 29 July 2011, 15:04 »
Ok, i have inspected and cleaned out every vacuum hose in the engine bay and replaced the brake booster line, as it looked as if it might be causing problems, but no luck...
Any ideas as what to try next?
Offline MK3 Menace
  • 98 GTI, big changes are coming...
Re: Idling problem
« Reply #4 on: 29 July 2011, 16:08 »
Did you check the hoses for splits or pinholes.
My main breather pipe from the top of the rocker cover to the crankcase had a tiny hole and would collapse on tickover and low revs. Might be worth a look...
