Author Topic: Mk2 fusebox - how to remove?  (Read 6453 times)
Offline jmsheahan
« on: 25 July 2011, 17:46 »
Probably a stupid question but bare with me!  :rolleyes: How the flying christ does the fusebox on a mk2 drop down? Cheers!
Offline The Mighty Elvi
  • I'm better than you today.
Re: Mk2 fusebox - how to remove?
« Reply #1 on: 25 July 2011, 18:30 »
Offline jmsheahan
« Reply #3 on: 26 July 2011, 10:13 »
Ta guys.
So there's 2 of those white clips? I had the left side loose but couldn't see another clip on the right.
Offline lemski
  • 16v
« Reply #4 on: 26 July 2011, 11:14 »
There normally pushed right up and hard to see. Does my head in
Offline weazgti
« Reply #5 on: 26 July 2011, 14:12 »
i only ever seen one and the other side is hanging in so you have to push fusebox up to get it off its lug
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #6 on: 04 August 2011, 00:51 »
Did you sort this??
CE2 - As I said... Move the white side locker down to the horizontal and then pull it off, then release fuse box from the metal bracket on the left side, the fuse box should move forward from the top,  then lift out the bottom pegs.... Box should be clear now!!
CE1 is a different ball game all together... PITA!!!
For More Info Click To See;
