Author Topic: help  (Read 1333 times)
Offline stupid
help
« on: 13 April 2005, 12:06 »
Hi . i have recently bought a golf mk2 16v .the car was fine for 700 miles then started to misfire at 6500 rpm so i changed plugs and put some injector cleaner in .ran well for a day or two then it got worse .it wont rev past 3000 rpm with any throttle on , if i lift off throttle it will rev a bit more . it is fine when i first start up , but gets worse as it gets warm .
any help on where to start would be appreciated
PS where is fuel filter and is it much of a job to change it ?
Offline LPG'd Oakie
  • Haha...I own one now!!!...And it works...ish
Re: help
« Reply #1 on: 13 April 2005, 12:13 »
Check your HT leads, If they are knackered the problem will get worse as they heat up.
Also check your rotor arm and dizzie cap.
Offline Gambit
Re: help
« Reply #2 on: 13 April 2005, 12:35 »
check the dizzy itself isnt loose - its connected to the bolt by 2 bolts. if these are loose then the dizzy can rotate and knacker the timing
Offline stupid
Re: help
« Reply #3 on: 14 April 2005, 23:06 »
i changed the coil today and it seems to have cured the problem . still a bit of a misfire on top end so i will change dizzy tomorrow .
Offline Gambit
Re: help
« Reply #4 on: 15 April 2005, 09:28 »
if your changing the actual dizzy itself & not just the cap n rotor then make sure you mark the centre line of the dizzy with the head otherwise you'll need to set the timing again once the new one is fitted
diagnosis-dub
Re: help
« Reply #5 on: 15 April 2005, 14:15 »
I think the problem was the hall sender in the old coil as when these go it gives the exact conditions you discribed.
Was the old coil leaking oil through it?
