Author Topic: no turbo and no codes  (Read 10360 times)
Offline Rhyso
Re: no turbo and no codes
« Reply #10 on: 24 July 2011, 21:20 »
down im poole fella :)
erm yeah with abit of asking im sure i could find someone, is there a way to test it then?
I think there is an output test of some kind for the N75 valve which opens and closes the vanes on the turbo.  You can hear the engine pitch change when it does this  :smiley:
Offline jlw41
« Reply #11 on: 24 July 2011, 21:27 »
ahh right ill get asking about nicely now then  :grin:
is there anything else it could be that i could look for or use vag com for while im there?
Offline Rhyso
« Reply #12 on: 24 July 2011, 21:29 »
You can log requested vs actual boost so that will give an indication of if you have either a boost leak or a fooked turbo
Does your turbo make any noise at all when you rev the engine? Can you hear it at all?
Offline jlw41
« Reply #13 on: 24 July 2011, 21:31 »
i think theres a slight whisle but thats about it not as loud as before though
Offline Rhyso
« Reply #14 on: 24 July 2011, 21:36 »
Lost any oil?? Any smoke coming from the exhaust?
Offline jlw41
« Reply #15 on: 24 July 2011, 21:39 »
nope hasnt used any oil sice ive had it and no smoke that ive noticed apart from the occasional bit when you boot it but thats just part of having a derve isnt it?  :grin:
Offline Rhyso
« Reply #16 on: 24 July 2011, 21:43 »
Small amount of black smoke is usual  :smiley:
Offline jlw41
« Reply #17 on: 24 July 2011, 21:47 »
thats all good then, so a list of stuff to double check tomorrow after work is
vac lines
boost leaks
actuactor movement
try and find someone with vag com to test the n75
anything else?
Offline Rhyso
« Reply #18 on: 24 July 2011, 21:51 »
vac lines
boost leaks
actuactor movement
anything else?
Pray it isn't your turbo lol
Good luck and let us know  :smiley:
Offline jlw41
« Reply #19 on: 24 July 2011, 21:53 »
yeah i dont fancy the bill for that!  :grin:
cheers for the help!!
