Author Topic: no turbo and no codes  (Read 10357 times)
Offline jlw41
« on: 24 July 2011, 15:05 »
hi, im faily new to the mk4 scene, got my self a mk4 gt tdi 115 a month or 2 ago :)
but now i have no boost and no fault codes and im kind of stuck with what it could be? im thinking possibly n75?
a few weeks ago i had a vnt clean and wd40'd the actuactor as it had been sat for a year ish and had an overboost problem and this sorted that
any help or advise would be great! thanks :)
Offline jlw41
Re: no turbo and no codes
« Reply #1 on: 24 July 2011, 16:52 »
ok just a quick uptate, just scanned it again after a spin and its back to 17958
Offline Adam
« Reply #2 on: 24 July 2011, 18:39 »
Huge boost leak? Check your pipes.
Down Hill From Here.
Offline jlw41
« Reply #3 on: 24 July 2011, 18:53 »
ive checked all the pipes and cant find a leak anywhere :(
Offline Adam
« Reply #4 on: 24 July 2011, 19:13 »
Checked the vacuum lines?
Offline jlw41
« Reply #5 on: 24 July 2011, 20:52 »
yeah ive checked them too and they all seem fine to  :undecided:
Offline Rhyso
« Reply #6 on: 24 July 2011, 20:59 »
Got a mate with an N75 valve you can try?
http://www.myturbodiesel.com/1000q/multi/limp-mode-TDI-fix.htm
Offline jlw41
« Reply #7 on: 24 July 2011, 21:10 »
nope i dont know anyone else with one, unless the 110 is the same part?
there only about £25 from tps i think so ill give it ago  :smiley:
it did always used to buzz after i turned the car off and now it doesnt do anything?
Offline Rhyso
« Reply #8 on: 24 July 2011, 21:13 »
Whereabouts you located? Anyone near you with VAGCOM?
Offline jlw41
« Reply #9 on: 24 July 2011, 21:14 »
down im poole fella :)
erm yeah with abit of asking im sure i could find someone, is there a way to test it then?
