Author Topic: Help Tdi anniversary  (Read 2756 times)
Offline Mr Roff
  • 1999 1.8 GTI AGU
« on: 24 July 2011, 14:05 »
Hi guys my friends 52 plate tdi anni
Has developed a knocking in the engine
Is sounds ok on tick over but when you
Get the revs up develops a loud knock from
The cam belt side of the rocker cover any
Ideas or thoughts would be appreciated
Thanks Gareth
Offline Steve_PD
Re: Help Tdi anniversary
« Reply #1 on: 24 July 2011, 21:29 »
multiply knocks or a single knock?
might be worth taking the cam cover off and checking the lobes and followers for wear  :sad:
Offline Mr Roff
  • 1999 1.8 GTI AGU
« Reply #2 on: 25 July 2011, 18:44 »
It sounds like one lobe sounds like a machine-gun
When you rev it but sounds normal on tick
Over rev to about 2500 and it starts do you think
It could be getting starved of oil. Poss strainer blocked
Thanks gareth
Offline Steve_PD
« Reply #3 on: 25 July 2011, 20:01 »
sounds like the cam is worn, heres my thread from last year
http://www.golfgtiforum.co.uk/index.php?topic=140425.0
if it is dont expect much change from £900 :cry:
Offline Mr Roff
  • 1999 1.8 GTI AGU
« Reply #4 on: 26 July 2011, 19:53 »
Thanks for the link it's exactly what you
Described even down to the turbo flutter
Can't thank you enough Gareth
