Author Topic: mk1 gti not started for 2 years, help  (Read 9725 times)
Offline neilsmk1
« on: 23 July 2011, 22:37 »
Hi guys, my mk1 golf has not been started for 2 years. Every so often i have cranked it over to avoid ceasing. Today i have finally got round to having a go at getting it running. I managed to get it to start but only runs for a couple of seconds. I have fuel up to the fuel filter but when i losen off the injector pipes on the top of the metering unit there is none. If i continue to start the car after approx 3 times i will not fire up, however if i leave it for a few minutes then it fires up and runs for a few seconds. Any ideas!
Thanks
Re: mk1 gti not started for 2 years, help
« Reply #1 on: 23 July 2011, 23:38 »
I would start with draining the fuel tank and trying fresh fuel.
Offline SoundillusioN
« Reply #2 on: 24 July 2011, 02:23 »
^^^ This plus there may be loads of sh*t in the tank/system. what condition did you leave the car in when you put it to bed?
I would also check to see if your fuel pump is working correctly.  When you turn the key to position 2, can you hear the pump prime for a couple of seconds? When yuo go to start the car and it runs for those few seconds, can you hear the pump running again?
Offline neilsmk1
« Reply #3 on: 24 July 2011, 19:46 »
It's been garaged all the time. The tank had very little in it before i put a jerry can full in.
« Reply #4 on: 24 July 2011, 20:36 »
I meant condition of the car before you put it in the garage, filters, fuel etc.  For reference, its not best to store a car with naff all fuel in it.  You're probably going to need a new filter and more fuel in it than a jerry can,  it will be pulling in crud from the bottom of the tank and possibly blocking up the filter.
Have you checked the pump operation yet like I suggested?
Offline raferackstraw
« Reply #5 on: 24 July 2011, 21:26 »
if no fuel to injectors but fuel getting to metering head then i would say that the metering head is gummed up with crap and therefore fubar, try a known working metering head
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline neilsmk1
« Reply #6 on: 25 July 2011, 18:20 »
yes the pump is fine, Can the metering unit be taken apart and cleaned or is it specialist.
« Reply #7 on: 25 July 2011, 19:02 »
It can be removed and cleaned intact.  Seriously wouldn't recommend taking it to bits, its a very complex bit of kit, specialist only.  As said, source another one if its at fault.
Offline neilsmk1
« Reply #8 on: 26 July 2011, 22:44 »
The golf now starts and runs nicely, seems to have sorted itself. Happy days. :grin:
« Reply #9 on: 26 July 2011, 22:52 »
Nice one... must have blown some sh*t out somewhere!... whats the plan now then?
