Author Topic: Golf Gti Mk3 Misfire  (Read 889 times)
Offline BazMK1
« on: 23 July 2011, 21:47 »
Hi
I have a Golf Gti MK3 GTi 2.0 8V that has a misfire problem.
I have had it on the diagnostic machine at work and its come up with the following error:
01252 - Injector Cylinder 4 - N33 Short with Ground
I Have done a Ohms test on the injector which off auto data says it should be 14 - 18.  The injector on the car is 14.9.
Also have checked the supply voltage and that is 12.4V which it should be 11-14V when cranking the engine.
On the autodata it says you can check the signal,  Says you put an LED between terminals 1 & 2 in the wiring to the injector,  and says the LED should flash....  I have done this but the LEd doesnt flash when cranking the engine,  it just stays illuminated.
Does this mean that there is a problem with the signal to the injector?
Thanks for your time
Baz
Offline Gti Gerbil
Re: Golf Gti Mk3 Misfire
« Reply #1 on: 24 July 2011, 21:00 »
not sure if the injectors on the golf are "earth switching" or "live switching"
but if they are earth switching and it has a short to earth then the led will be constantly on.
is fuel getting up to the cylinders at all ?
find me on skype : paul.taylor.999 .. Vagcom reads for all, with a free cup of tea
Offline Gti Gerbil
« Reply #2 on: 24 July 2011, 21:01 »
have you checked all the injectors, or just one ?
