Author Topic: FUSES fuse locations  (Read 199117 times)
Offline Snoopy
  • Moderator
  • Geoff.
« on: 22 July 2011, 19:49 »
I think this diagram is for LHD so you may have to reverse the way you look at it, eg. Fuse 1 is top right
Cars from Novemember 2009
F1 - Fuse 1 on fuse holder C -SC1- 10 A
         16-pin connector -T16- Diagnostic connection 15a
          Switch and instrument illumination regulator -E20-
          Air mass meter -G70-
          Auxiliary heater operation relay -J485-
          Electronically controlled damping control unit -J250-
          Headlight range control unit -J431-
          Heater element for crankcase breather -N79-
          Left headlight range control motor -V48-
          Right headlight range control motor -V49-
          Adaptive cruise control unit -J428-
          Headlight range control regulator -E102-
          Brake light switch -F-
          Park assist steering control unit -J791-
          Actuator for structure-borne sound -R214-3
          Voltage stabiliser -J532-5
F2 - Fuse 2 on fuse holder C -SC2- 10 A
          Light switch -E1- 15a
          ABS control unit -J104-
          Control unit in dash panel insert -J285-
          Trailer detector control unit -J345-
          Power steering control unit -J500-
          Data bus diagnostic interface -J533-
          Fuel pump control unit -J538-
          Voltage stabiliser -J532-2
          Selector lever sensors control unit -J587-
          Fuel pump relay -J17-1
          Engine control unit -J623-4
          Driving program button -E598-3
          Starter relay 1 -J906-2
          Starter relay 2 -J907-2
          Mechatronic unit for dual clutch gearbox -J743-
          All-wheel drive control unit -J492-
F3 - Fuse 3 on fuse holder C -SC3- 5 A
      Airbag control unit -J234- 15a
F4 - Fuse 4 on fuse holder C -SC4- 5 A
         High-pressure sender -G65- 15a
          Oil level and oil temperature sender -G266-
          Seat occupied recognition control unit -J706-
          Automatic anti-dazzle interior mirror -Y7-
          Air quality sensor -G238-
          Reversing light switch -F4-
          TCS and ESP button -E256-
          Heater/heat output switch -E16-
          Garage door opener button 1 -E392-
         Tyre pressure monitor display button -E492-
         Anti-dazzle interior mirror button -E386-
          Air conditioning system delay relay -J70-
          Start/Stop operation button -E693-2
F5 - Fuse 5 on fuse holder C -SC5- 10 A
      Control unit for cornering light and headlight range control -J745- right 15a
F6 - Fuse 6 on fuse holder C -SC6- 10 A
      Control unit for cornering light and headlight range control -J745- left -
F7 - Fuse 7 on fuse holder C -SC7- - - Not assigned -
F8 - Fuse 8 on fuse holder C -SC8- - - Not assigned -
F9 - Fuse 9 on fuse holder C -SC9- - - Not assigned -
F10 - Fuse 10 on fuse holder C -SC10- - - Not assigned -
F11 - Fuse 11 on fuse holder C -SC11- - - Not assigned -
F12 - Fuse 12 on fuse holder C -SC12- 10
         Driver door control unit -J386- Central locking 30a
          Front passenger door control unit -J387- Central locking
F13 - Fuse 13 on fuse holder C -SC13- 10 A
         Light switch -E1-
         Rain and light sensor -G397-
         Heated rear window relay -J9-
         Fog light switch -E7-
         Magnetic field sender for compass -G197-
F14 - Fuse 14 on fuse holder C -SC14- 10 A
        Climatronic control unit -J255- 30a
         Air conditioning system control unit -J301-
          Automatic gearbox control unit -J217-
         Tiptronic switch -F189-
          Remote control receiver for auxiliary coolant heater -R149-
          Onboard supply control unit -J519-
F15 - Fuse 15 on fuse holder C -SC15- 20 A
         Rear left door control unit -J388- Central locking
       - Rear right door control unit -J389- Central locking 30a
          Rear lid handle release button -E234- 30a
F16 - Fuse 16 on fuse holder C -SC16- 10 A
        Reversing camera -R189-
F17 - Fuse 17 on fuse holder C -SC17- 10 A
         Alarm horn -H12- 30a
         Interior monitor send and receive module 1 -G303-
         Interior monitor send and receive module 2 -G305-
         Vehicle inclination sender -G384-
          Dual tone horn relay -J4-
F18 - Fuse 18 on fuse holder C -SC18- - - Not assigned -
F19 - Fuse 18 on fuse holder C -SC19- 5 A
         Special vehicle control unit -J608- 30a
          Engine speed governor control unit -J542-
F20 - Fuse 20 on fuse holder C -SC20- - - Not assigned -
F21 - Fuse 21 on fuse holder C -SC21- - - Not assigned -
F22 - Fuse 22 on fuse holder C -SC22- 40 A
        Fresh air blower control unit -J126- 30a
F23 - Fuse 23 on fuse holder C -SC23- 30 A
          Driver door control unit -J386- Window regulator 30a
          Front passenger door control unit -J387- Window regulator
F24 - Fuse 24 on fuse holder C -SC24- 20 A
        Onboard supply control unit -J519- 30a
F25 - Fuse 25 on fuse holder C -SC25- 25 A
        Heated rear window -Z1- 30a
          Fresh air blower relay -J13-
F26 - Fuse 26 on fuse holder C -SC26- 30 A
        Rear left door control unit -J388- Window regulator 30a
         Rear right door control unit -J389- Window regulator
F27 - Fuse 27 on fuse holder C -SC27- 15 A
        Fuel pump control unit -J538- 30a
         Fuel supply relay -J643-
         Relay for supplementary fuel pump -J832-
F28 - Fuse 28 on fuse holder C -SC28- 15 A
          Radio -R-2 30a
          TV tuner -R78-2
          Control unit with display for radio and navigation -J503-2
F29 - Fuse 29 on fuse holder C -SC29- - - Not assigned -
F30 - Fuse 30 on fuse holder C -SC30- 20 A
        Automatic gearbox control unit -J217- 30a
F31 - Fuse 31 on fuse holder C -SC31- 20 A
        Vacuum pump for brakes -V192- 30a
F32 - Fuse 32 on fuse holder C -SC32- 30 A
      DC/AC converter with socket, 12 V - 230 V -U13- 30a
      10 A   Special vehicle control unit -J608-
F33 - Fuse 33 on fuse holder C -SC33- 25 A
        Sliding sunroof adjustment control unit -J245- 30a
F34 - Fuse 34 on fuse holder C -SC34- 15 A
        Driver seat lumbar support adjustment switch -E176- 30a
         Front passenger seat lumbar support adjustment switch -E177-
F35 - Fuse 35 on fuse holder C -SC35- 10 A
        Electronically controlled damping control unit -J250- 30a
F36 - Fuse 36 on fuse holder C -SC36- 20 A
        Headlight washer system relay -J39- 30a
          Headlight washer system pump -V11-
F37 - Fuse 37 on fuse holder C -SC37- 30 A
       Heated front seats control unit -J774- 30a
F38 - Fuse 38 on fuse holder C -SC38- - - Not assigned -
F39 - Fuse 39 on fuse holder C -SC39- - - Not assigned -
F40 - Fuse 40 on fuse holder C -SC40- 40 A
        Air conditioning system control unit -J301- 75a
F41 - Fuse 41 on fuse holder C -SC41- 15 A
        Rear window wiper motor -V12- 75a
F42 - Fuse 14 on fuse holder C -SC42- 20 A
        Blocking diode 2 -J811- 75a
         Cigarette lighter -U1-
         12 V socket -U5-
F43 - Fuse 43 on fuse holder C -SC43- 15 A
        Trailer detector control unit -J345- 30a
F44 - Fuse 44 on fuse holder C -SC44- 20 A
F45 - Fuse 45 on fuse holder C -SC45- 15 A
F46 - Fuse 46 on fuse holder C -SC46- - - Not assigned -
F47 - Fuse 47 on fuse holder C -SC47- 5 A
        Control unit in dash panel insert -J285-2 30a
F48 - Fuse 48 on fuse holder C -SC48- 10 A
        Magnetic field sender for compass -G197-2
        - Mobile telephone operating electronics control unit -J412-2 30a
F49 - Fuse 49 on fuse holder C -SC49- - - Not assigned
« Last Edit: 23 July 2011, 14:04 by Snoopy »
Mk6 GTI  &  Mk1 GTI
35 years of GTI ownership.
Offline The Doc
  • E63s Estate - Vito Sport
Re: FUSES fuse locations
« Reply #1 on: 22 July 2011, 21:23 »
Thanks for that, my manual doesn't have these.....
Offline mike.
« Reply #2 on: 23 July 2011, 14:07 »
This is the other fuse box to the right of the battery
There are a lot of duplications in these lists so it seems to depend on what options are fitted to the car where the fuse position are.
At least it should get you a bit closer than nothing at all  :smiley:
F1 - Fuse 1 on fuse holder B -SB1- - - Not assigned -
F2 - Fuse 2 on fuse holder B -SB2- 30 A
        Mechatronic unit for dual clutch gearbox -J743- 30a
        Engine component current supply relay -J757-7
F3 - Fuse 3 on fuse holder B -SB3- 20 A
         Battery monitor control unit -J367-6
F4 - Fuse 4 on fuse holder B -SB4- 30 A
         ABS control unit -J104- 30a
F5 - Fuse 5 on fuse holder B -SB5- 15 A
F6 - Fuse 6 on fuse holder B -SB6- 5 A
        Control unit in dash panel insert -J285- 30a
        Steering column electronics control unit -J527-
F7 - Fuse 7 on fuse holder B -SB7- 40 A - Terminal 15 voltage supply relay -J329- 30a
F8 - Fuse 8 on fuse holder B -SB8- 15 A
        Radio -R- 30a
        TV tuner -R78-
        25 A - Control unit with display for radio and navigation -J503-
        Voltage stabiliser -J532-6
F9 - Fuse 9 on fuse holder B -SB9- 5 A
        Mobile telephone operating electronics control unit -J412- 87a
F10 - Fuse 10 on fuse holder B -SB10- 10 A
          Engine control unit -J623- 30a
          Terminal 30 voltage supply relay -J317-
          Main relay -J271-
          5 A - Motronic current supply relay -J271-
F11 - Fuse 11 on fuse holder B -SB11- 20 A
         Auxiliary heater control unit -J364- 30a
F12 - Fuse 12 on fuse holder B -SB12- 5 A
         Data bus diagnostic interface -J533- 30a
F13 - Fuse 13 on fuse holder B -SB13- 15 A
         Engine control unit -J623-4 87a
         30 A - Engine control unit -J623-5
F14 - Fuse 14 on fuse holder B -SB14- 20 A
         Ignition transformer -N152-10 87a
         Ignition coil 1 with output stage -N70-
         Ignition coil 2 with output stage -N127-
         Ignition coil 3 with output stage -N291-
         Ignition coil 4 with output stage -N292-
F15 - Fuse 15 on fuse holder B -SB15- 5 A
          Fuel pump relay -J17- 87a
          Electric fuel pump 2 relay -J49-
          Low heat output relay -J359-
          High heat output relay -J360-
      5 A - Automatic glow time control unit -J179-
      10 A - Fuel system diagnostic pump -V144-7
          Radiator identification sensor -G611-7
          Lambda probe heater -Z19-
          Lambda probe 1 heater after catalytic converter -Z29-3 , 11
          Lambda probe heater 3 -Z62-2
          Injector, cylinder 1 -N30-12
          Injector, cylinder 2 -N31-12
          Injector, cylinder 3 -N32-12
          Injector, cylinder 4 -N33-12
F16 - Fuse 16 on fuse holder B -SB16- 30 A
         Front right turn signal bulb -M7- 30a
         Rear right turn signal bulb -M8-
         Right brake light bulb -M10-
         Right tail light bulb -M2-
         Right side light bulb -M3-
         Right reversing light bulb -M17-
         Right headlight dipped beam bulb -M31-
         Right headlight main beam bulb -M32-
         Right fog light bulb -L23-
F17 - Fuse 17 on fuse holder B -SB17- 15 A
         Dual tone horn relay -J4- 30a
         Bass horn -H7-
         Treble horn -H2-
F18 - Fuse 18 on fuse holder B -SB18- 30 A
          Amplifier -R12- 30a
          30 A   Special vehicle control unit -J608-
F19 - Fuse 19 on fuse holder B -SB19- 30 A
          Windscreen wiper motor -V- 30a
          Driver side windscreen wiper motor -V216-
          Wiper motor control unit -J400-
F20 - Fuse 20 on fuse holder B -SB20- 10 A
          Coolant circulation pump -V50- 30a
          20 A - Fuel pressure regulating valve -N276-8 , 13 , 14 , 8
F21 - Fuse 21 on fuse holder B -SB21- 10 A
          Lambda probe heater -Z19- 87a
          10 A - Lambda probe heater 2 -Z28-
          10 A - Magnetic clutch for supercharger -N421-
          15 A - Lambda probe 1 heater after catalytic converter -Z29-
          15 A - Front passenger door central locking motor -V57-
          20 A - Vacuum pump for brakes -V192-9
F22 - Fuse 22 on fuse holder B -SB22- 5 A
         Clutch position sender -G476- 87a
F23 - Fuse 23 on fuse holder B -SB23- 10 A
          Charge pressure control solenoid valve -N75- 87a
          Exhaust gas recirculation cooler changeover valve -N345-15
          15 A   Turbocharger air recirculation valve -N249-
            Secondary air inlet valve -N112-1
          - Fuel system diagnostic pump -V144-1
          15 A - Fuel pressure regulating valve -N276-
          Secondary air pump relay -J299-10 , 7
          5 A - Continued coolant circulation relay -J151-7
F24 - Fuse 24 on fuse holder B -SB24- 10 A
         Camshaft control valve 1 -N205- 30a
         Radiator fan -V7-
         Activated charcoal filter solenoid valve 1 -N80-
         Variable intake manifold changeover valve -N156-
         Throttle valve module -J338-
         Auxiliary coolant pump relay -J496-11
         Valve for oil pressure control -N428-8
F25 - Fuse 25 on fuse holder B -SB25- 40 A
          ABS hydraulic pump -V64-
F26 - Fuse 26 on fuse holder B -SB26- 30 A
          Left side light bulb -M1-
         Front left turn signal bulb -M5-
         Left tail light bulb -M4-
         Rear left turn signal bulb -M6-
         Left brake light bulb -M9-
         Left headlight dipped beam bulb -M29-
         Left headlight main beam bulb -M30-
         Left reversing light bulb -M16-
         Rear left fog light bulb -L46-
         Left fog light bulb -L22-
F27 - Fuse 27 on fuse holder B -SB27- 50 A
          Automatic glow period control unit -J179- 30a
          40 A   Secondary air pump motor -V101-
F28 - Fuse 28 on fuse holder B -SB28- - - Not assigned -
F29 - Fuse 29 on fuse holder B -SB29- 50 A
          Fuse 32 on fuse holder C -SC32- 30a
          Driver seat adjustment thermal fuse 1 -S44-
F30 - Fuse 30 on fuse holder B -SB30- 50 A
        X-contact relief relay -J59-
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Keithuk
« Reply #3 on: 23 July 2011, 14:46 »
Correct Doc then handbook says
Quote
At the time of print we are unable to provide an up-to-date overview of the locations of the fuses for the electrical consumers. This is because the vehicle is under constant development, because fuses are assigned differently depending on the equipment level and because several consumers may use a single fuse. You can get more information about the fuse layout from a Volkswagen dealership.
What a load of bull, the Golf is being developed all the time so you will never see a fuse location in the handbook they are just making you take a trip to the dealer? They should show the location of what they know up to press?
Even with Mike's picture it shows an additional fuse depending on the year?
I use Autodata so that gives me the location, what it controls and the fuse rating? Even Autodata shows different things for different years.
« Last Edit: 08 November 2013, 20:58 by Keithuk »
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline The Doc
« Reply #4 on: 23 July 2011, 20:32 »
They are deviants  :evil:
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #5 on: 23 July 2011, 20:35 »
Thanks Mike.  :cool: :smiley:
Mk6 GTI  &  Mk1 GTI
