Author Topic: random switch question  (Read 1493 times)
Offline Gareth
« on: 22 July 2011, 19:18 »
bit of a random one but does any one know if this will fit along side the other switches on the mk2 dash?
http://www.ebay.co.uk/itm/VW-B3-Passat-ABS-Brake-Warning-Light-357919235A-91-93-/290496319841?pt=Motors_Car_Truck_Parts_Accessories&hash=item43a2ee1161
cheers
Offline The Mighty Elvi
  • I'm better than you today.
Re: random switch question
« Reply #1 on: 22 July 2011, 22:02 »
Why?
You have no ABS and you already have a handbrake light.
Offline Gareth
« Reply #2 on: 23 July 2011, 03:32 »
I have abs from a b3 passat fitted to my mk2 :D
« Reply #3 on: 23 July 2011, 12:01 »
Well, now that you've made that clear.  :grin:
Do you have the wiring loom and sensor from the B3? Or is the switch just for scene points?
Offline Gareth
« Reply #4 on: 23 July 2011, 12:32 »
Yeah i have used the full abs loom, Ecu, abs rings, sensors and pump it's all in and fully working :) the abs light unit that was in the b3 would not fit the dash with out modifying and I don't really want to start hacking at it
« Reply #5 on: 23 July 2011, 13:12 »
Well without having the dimensions of the switch it seems that if it it too small to fit the Golf switch hole, I suggest you cut a hole in a golf switch blank and fabricate a frame for the ABS switch. Or get a flat piece of black perspex and do as above for a flush fitting switch. The switch blanks are cheap enough to have a go until it looks right.
Offline Gareth
« Reply #6 on: 23 July 2011, 15:28 »
Yeah I guess that does seam like a waste of money thinking about it :)
Thanks
Offline Mr Blue
« Reply #7 on: 23 July 2011, 15:57 »
go on US ebay and fine a mk2 one with the abs light
