Author Topic: 16v distributor seal change  (Read 1333 times)
Offline Captain Puke
« on: 21 July 2011, 13:08 »
Hi all,
  I need to replace my oil seal this weekend, is it possible to do this without a timing gun?  Can I just mark the dizzy position before disassembly and return when it goes back in?
Obvious question but I don't really do cars!
Offline SoundillusioN
Re: 16v distributor seal change
« Reply #1 on: 21 July 2011, 13:33 »
Hi all,
In short yes, usually applies to all/most parts of the timing gear.. if marked up when removed you should be fine if you put it back just as it was. cambelts are often done this way,
« Reply #2 on: 21 July 2011, 13:38 »
Yes, mark it and it will be fine might still be worth getting the timing checked afterwards anyway.
« Reply #3 on: 21 July 2011, 16:55 »
Ok cheers, will give it a go. Thanks!
