Author Topic: Scirrocco Engine the same a s a mk2 golf?  (Read 1787 times)
Offline sill-skimmin'
  • Yes, it does catch. On everything.
« on: 12 April 2005, 18:43 »
Hello all,
I have been offered a Scirocco gti for £150, the engine is what I am after as mine is damaged beyond repair.
Does anyone know if they are the same engine?
The golf is a 1800 8v, unsure about the scirrocco tho?
Any idea's peeps?
Thanks in advance, Mark  :smiley:
1987 Mk2 GTi 8v. Full strip out. LUKE harnesses. Drilled Airbox. 14" BBS. Slammed on Coilovers.? Plastic arches fell off. Side of splitter hanging. Weight reduction by 'Rust Motorsport'
Offline richandhazel
Re: Scirrocco Engine the same a s a mk2 golf?
« Reply #1 on: 12 April 2005, 18:58 »
Hello all,
Any idea's peeps?
If the Scirocco is 1800 then yeah, basically it will be the same..........got some engine codes?
Offline Gambit
« Reply #2 on: 13 April 2005, 10:21 »
it'll be the same setup as the mk1 Golf GTI i.e. the Fuel Regulator & throttle body positioning etc will be different to that of a mk2.
free
« Reply #3 on: 13 April 2005, 18:02 »
if its a k-jet it will be the same :wink:
Offline AudiA8Quattro
« Reply #4 on: 13 April 2005, 18:56 »
Gambit is right, it will be like a mk1.
The servo and brake master cylinder is on the right, like for a LHD. So some parts will be needed to swap to make it work.
« Reply #5 on: 14 April 2005, 02:27 »
Yeah, the basic engine itself should be fine.........Gambit is correct about the layout being different. I assume you'll already have all that and its just the engine itself that you need :undecided:
diagnosis-dub
« Reply #6 on: 14 April 2005, 04:19 »
If its the same set up as the MK1 GTI then the engine code should be a DX
