Author Topic: problem !!!!!!  (Read 15283 times)
Offline DubaiGTI
Re: problem !!!!!!
« Reply #10 on: 21 July 2011, 11:38 »
It sounds like the fuel pump.  Mine needed replacing after just 1000km.  It's happened to a few people I know here in Dubai.
VW replaced this in 48hrs and the car is running fine now 5000km later.
Offline C3PO
Re: problem !!!!!!
« Reply #11 on: 21 July 2011, 17:46 »
As usual you have come back quickly with some examples. I will keep you all posted. Although reading the forum on mark 6's it would appear the mechanic could revs the nuts off it. Wont be happy if I see that :angry:
Also anyone had a strange screeching noise (no not the tyres) when you quickly drive forwards, stop and then reverse? \tried to make the clutch slip, but seemed fine, and only does it once every 2-4 weeks. :shocked:
Mk6 GTI, 18" monza shadows, Leather, Bluetooth Phone - gone
Mark 7 R, 19" wheels, lapiz blue, 5 door, leather, reversing camera - gone
2018 Audi S5 Sportback, pano roof, LED Headlights  B&O sound system - gone
Current 2020 Golf GTI TCR, pure grey, pano roof , 90% tints and Akrapovic exhaust.
Offline Snoopy
  • Moderator
  • Geoff.
Garage:
35+ years of GTI ownership.
Offline C3PO
Re: problem !!!!!!
« Reply #13 on: 23 July 2011, 14:37 »
Thanks, not sure if thats the right noice, i think is more a clutch/bearing sounds, but because it does not happen all the time its a bit baffling. :undecided:
Offline Snoopy
  • Moderator
  • Geoff.
Re: problem !!!!!!
« Reply #14 on: 23 July 2011, 14:51 »
C3PO
Is yours doing what mines doing?
http://www.golfgtiforum.co.uk/index.php?topic=199507.0
 :sad:
It does not seem to do it all the time though. :sad:
« Last Edit: 23 July 2011, 14:53 by Snoopy »
Garage:
Offline C3PO
Re: problem !!!!!!
« Reply #15 on: 24 July 2011, 20:54 »
Thats almost identifical, mine starts around 2K - 2.5k, the description of hiccup is perfect. Did you get your problem resolved?
Offline Snoopy
  • Moderator
  • Geoff.
Re: problem !!!!!!
« Reply #16 on: 24 July 2011, 20:55 »
Its on my list to discuss when i visit the dealer tomorrow to book it in for the alarm issue
Garage:
Offline C3PO
Re: problem !!!!!!
« Reply #17 on: 24 July 2011, 21:00 »
Mines at the dealer tomorrow too, will report back and see what they come up with. I will suggest fuel pumpo, coil pack and spark plugs from the advice so far. Dont really want an ECU update, from what I have read it ruins the car :sick:
Offline Snoopy
  • Moderator
  • Geoff.
Re: problem !!!!!!
« Reply #18 on: 25 July 2011, 13:34 »
If you could.
Mines in today for something else. Then back in a week tomorrow for a few other thing to be looked at including this issue so it would be intereted to know what they find out about yours to help and point them in that direction for mine.
Garage:
Offline C3PO
Re: problem !!!!!!
« Reply #19 on: 25 July 2011, 17:20 »
so, its been in today, and had the following treatment:
Test drive found there was a hiccup as described.
checked for software update - needed update, so update applied, then test drive to discover slight misfire under hard acceleration.
Removed all spark plugs and checked - found cracks in all spark plugs !!!! replaced and tested ok.
Been washed very well, and cleaned inside, which has saved me a job, although not quite to my standards, but saved me several hours :smiley:
Driven home (not far and all seems well). Given £25 in leisure vouchers as car been put in under warranty.
Time will tell. :lipsrsealed:
