Author Topic: Mk1 Rivage timing belt, how do you tighten it?  (Read 3695 times)
Offline H Singh
« on: 20 July 2011, 13:54 »
Hi
My rivage seems to be making an odd sound when i start it up and the cars a little cold or if i put the lights on, im guessing its tte belt that is loose ,as when the car is up and running at normal temp everything is okay..
was just wondering how you do this?
Harry
Offline SoundillusioN
Re: Mk1 Rivage timing belt, how do you tighten it?
« Reply #1 on: 20 July 2011, 15:00 »
Hi
Harry
Is it a screeching/squeeling sound on whining. If it's whining when the lights are on it could be a poorly Alternator when under load.  But because you say it makes a noise when cold but when warm it seems OK, it sounds like your belt is loose so its slipping and making a noise.  Very easy to tighten, there is an adjuster arm that the alternator moves along on, you just slacken the bolt (alternator end) pull the alternator upwards to take up the slack in the belt and do the bolt back up.  Might be worth starting the car and watching the belt, you can often see if its loose as it will flap about.
Offline H Singh
« Reply #2 on: 21 July 2011, 09:11 »
Brilliant buddy thanks alot i shall have a go at this on the weekend and see if it makes any difference..Cheers
« Reply #3 on: 21 July 2011, 09:43 »
No worries, if you come to do it and you get stuck, gimme a shout and i'll post a pic or something.
Offline H Singh
« Reply #4 on: 21 July 2011, 14:52 »
Brilliant.. if you get me a pic before i tried it that would be definatly useful! Thanks for you help much appreciated!
« Reply #5 on: 21 July 2011, 15:09 »
Found a pic on the net I could draw on.....
Loosen the bolt in the picture
To tighten belt, pull Alternator upwards, to loosen, push down, when the desired tension is met, tighten up the bolt again.  Try not to over tension the belt, there should be some play in it, enough that you can at least twist the belt 90 degrees.
Offline H Singh
« Reply #6 on: 25 July 2011, 15:05 »
Cheers buddy for the help
« Reply #7 on: 25 July 2011, 15:11 »
No problem... let us know if it solves it and if you need anything else, just give me a shout.  :wink:
