Author Topic: Pressure Washer & Foam Gun advice  (Read 1833 times)
Offline Max GTI
« on: 19 July 2011, 18:13 »
Hello Guys & Girls
Yes another pressure washer and foam gun question (sorry)  :wink:
I'm basically looking to get my first pressure washer and a foam gun (lance) if it’s what they’re called. I’ve had a look on the internet and on here and it seems like people go for a NILFISK or karcher. I’ve seen one of each and just wanted peoples opinion was.
It doesn’t need to be powerful as i want the paint to remain on the car :smiley: just to clean it and be able to attach a foam gun to it.
http://www.amazon.co.uk/Nilfisk-X-Tra-Pressure-Washer-Motor/dp/B001TUYV14/ref=cm_cr_pr_product_top
http://direct.tesco.com/q/R.209-6877.aspx
Also the foam gun attachment iv seen is this one.
http://www.cleanyourcar.co.uk/washing-and-drying/foam-lance-various-fittings/prod_371.html
I guess it will fit fine on the Karcher because the fitting is on the list (none pro one I assume) but will need to buy a different foam gun to fit on the NILFISK.
Thanks for the help in advance
Max
25th Anniversary
No. 1117
Offline tech1889
  • Mk2 GTI FTW !!
Re: Pressure Washer & Foam Gun advice
« Reply #1 on: 19 July 2011, 19:01 »
if getting nilfisk get the 130 from what ive been told as its all round better..
get your foam stuff from www.waxamomo.co.uk as we get forum discount and Chris is a top bloke  :wink: you spec which adaptor you want  :smiley:
Offline Max GTI
« Reply #2 on: 19 July 2011, 19:54 »
Thanks for the reply, Is it the NILFISK E130. That's about 200-300 quid  :shocked:
That website doesn't have the NILFISK addapter unless another manufacturers one will fit?
25th Anniversary
No. 1117
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #3 on: 20 July 2011, 10:00 »
If you pm Waxamomo he will point you in the right direction for everything you need if he hasnt got it im sure he will tell you where to get it.. its all about budget !
