Author Topic: new ecu  (Read 1700 times)
Offline Tazzy
new ecu
« on: 19 July 2011, 10:27 »
after eliminating every possible issue (water in the ecu and the engine sensors) the problem is still there, so ive bought a new ecu, however, the car starts but then soon cuts out, we believe its the immobilizer cutting in, can this be sorted?
thanks
If It Comes Off, Modify It!
Re: new ecu
« Reply #1 on: 19 July 2011, 10:47 »
What car ?
Offline Tazzy
Re: new ecu
« Reply #2 on: 19 July 2011, 11:09 »
sorry, should of stated
mk4 1.8 20v non-turbo gti (agn i believe?)
Re: new ecu
« Reply #3 on: 19 July 2011, 13:22 »
Yes it will need coding, can be done with vagcom I believe.
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: new ecu
« Reply #4 on: 21 July 2011, 20:59 »
Vagcom will match the ecu up, if you have issues then pop the ecu over to me and i will pair the immo and EEPROM on the bench for you. :-)
 01455 617233
