Author Topic: Mk4 Golf V6 4Motion Front Brake Calipers & Carriers do they a fit vr6  (Read 2704 times)
Offline etmv
hi im trying to find out if i can fit Mk4 Golf V6 4Motion Front Brake Calipers & Carriers & discs 312mm on to my 1995 mk3 vr6 with a 280mm setup i know that will need at least 16inch wheels to fit them in.please can anyone help
Offline sharki786
  • GOT BOOST??
depends on the alloys size you have on now, you should be able to get away with 17's, could i ask why your doing the 312mm convo?
*****MK3 Anniversary*****
*****MK4 GTI T*****
312mm will fit under 16" wheels all ok.
Offline sharki786
  • GOT BOOST??
+1
might need to shave abit of the caliper
*****MK4 GTI T*****
+1
Might not be needed, I tried a 16" steel on mine today and it cleared fine.
Offline etmv
the reason for the bigger brakes is the 280mm brakes are rubbish m8 just want to stop a bit better thanks for help people
Why not fit better quality pads and discs.
Offline etmv
hi m8 because it's cheap to do
