General discussion
wifi password
Topic: wifi password (Read 1464 times)
richard s
wifi password
16 July 2011, 20:47 »
i have sky which gives me a netgear router and i am unable to connect to the wifi on this router because i cant get the pasword so i need a bit of help.
when i first got my laptop i tried to go wireless but i could not log in using the ssid and the network key printed on the bottom of the router. my aunties husband came round and sorted it out but eventually it packed in and i used the cable to connect to the router. i have a new phone that has wifi on it so i want to use my sky router to connect to the internet but it comes up with a different ssid to what is printed on the bottom of my router and the password printed on the router doesnt work either so i cant connect
. is their a way of finding the password so i can connect using wifi
cheers
bodga
Here all the time
F reg GTI 16v
Re: wifi password
16 July 2011, 20:58 »
There should be a reset button on the router some were press it or google the router to find out how to reset to factory default.
you should then be able to log in with the ssid and password on the serial tag under the router. then log in to your router and change its password etc to something personal etc for security reasons cus come bright spark will know factory defaults of routers and log in to yours outside your house
Dolly
Re: wifi password
16 July 2011, 21:54 »
cant you hardwire it and type some sh!t into the brower address bar 192.168.0 or something? sure google can help you more than me
Seanl
Re: wifi password
16 July 2011, 21:57 »
I had the same thing. Contacted Sky and they ran me through it whilst I was on the line. You will have to plug into the router, and they will give you an ip adress, then run you through the options to change the ssid and password.
Bellend
Re: wifi password
16 July 2011, 22:38 »
Internet Explorer, go to 192.168.0.1
Username is: Admin
Password is : sky
Look on the left for wireless settings. Find the WPA or WEP code and write it down. Close the browser.
Where all my moneys went.
richard s
Re: wifi password
17 July 2011, 19:42 »
i got it sorted after going on 192.168.0.1. i eventually found the password and after a couple of tries i realised the password was case sensative and my phone was set to lower case :embarassed:
thanks for the help guys
Kerrse
Re: wifi password
Reply #6 on:
18 July 2011, 10:19 »
Once you have logged in the router change the router password & your wifi password, much easier to remember your own passwords
General discussion
wifi password
