Author Topic: Tapping/Knocking under my feet??  (Read 2988 times)
Offline Jimble
« on: 16 July 2011, 18:38 »
I don't know if it's just me going mad but just lately i can feel whats like a tapping or knocking coming through the pedals when moving, i can't feel it through the steering wheel at all, it's not a hard knock and feels almost like worn bushes or similar but as the car has done next to no miles really i doubt it's anything like that :angry:
I keep telling myself it's the cr@p Dunlop tires but i'm not sure? has anyone else experienced the same or similar and can shed some light?
Thanks
Offline Snoopy
  • Moderator
  • Geoff.
Re: Tapping/Knocking under my feet??
« Reply #1 on: 16 July 2011, 18:48 »
Do you do alot of quick pullaways? As it could be one of two common things.
The traction control can feel like a knocking.
The rubber bushes holding the exhaust could have gone faulty a common problem with the mk5 and iirc the mk6 is the same setup..
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline Jimble
« Reply #2 on: 16 July 2011, 19:59 »
Definatley not the traction control mate, it happens when rolling along if you know what i mean? :embarassed: but the exhaust thing sounds plausable, i just don't remember it doing it before, i wish i could drive another one to see if it's me going mad! or someone else with one drive mine, i wish i could get to the rolling road meet in october but i'm on my stag weekend then, dammit! :angry:
Offline GolfTi
  • ..gotta feel for my automobile..
« Reply #3 on: 16 July 2011, 20:20 »
I'd get those tyres thoroughly checked.
Mk7 GTI. DBP, DCC, Winter pack. Mine since new, July 2013.
GTI no. 4. Golf no. 5.  VW no. 7.
Offline Jimble
« Reply #4 on: 16 July 2011, 20:29 »
I may well do that tbh.
Offline andyr
« Reply #5 on: 17 July 2011, 17:51 »
Does it happen with foot on the clutch whilst moving. ie, free-wheeling, or is it harder/softer when braking?
Have you checked the obvious like a stone stuck somewhere. I once had a stone stuck in a vent in a brake disc and it was knocking against it's back plate.... But then I'd assume it would be felt in the steering??
Worth a check tho? and run your hand over the tyres to see if there's something stuck in the tread?
Mk VI Black Pearl GTD.... No Frills, replaced a Black Pearl PD150 Bora, which in turn replaced a Dragon Green VR6 which followed a Dusty Mauve MK III 8v Gti.
Offline Jimble
« Reply #6 on: 17 July 2011, 18:05 »
You can feel it when moving through the accelerator pedal and with foot rested on the clutch with no pressure, i had a quick look at the tyres but may have missed something i suppose, i did a 400 mile round trip last weekend and it was constant so if there is something in the tyre then it's probably going to be expensive! :sick:
Cheers for the reply mate.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #7 on: 17 July 2011, 18:12 »
I still have a feeling its the big metal clamp for the exhaust at the front. Its red bushed fail on the mk5 and im sure the last time i was under my mk6 it was the same clamp.
Ignore the big red chunk of metal  :grin: but you see the red bushes near the front of the car on the alloy engine subframe. (bottom right of the photo) They are a known week spot.
« Last Edit: 17 July 2011, 18:19 by Snoopy »
Mk6 GTI  &  Mk1 GTI
Offline Jimble
« Reply #8 on: 17 July 2011, 18:46 »
Hmm, could i reach that lying next to the car? i don't have any axle stands and i'm not crawling under it on the factory jack!
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #9 on: 17 July 2011, 18:47 »
I just did it in the garage to check there the same on the mk6 :wink:
Mk6 GTI  &  Mk1 GTI
