Author Topic: vw golf tdi mk3  (Read 1055 times)
Offline mad4vws
vw golf tdi mk3
« on: 16 July 2011, 18:36 »
hi all , was thing of fitting a bigger turbo on my golf(it's fast but want it to go faster)will a mk4 golf 130 bhp or passat 1 fit ?.
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: vw golf tdi mk3
« Reply #1 on: 21 July 2011, 21:49 »
I believe so, have you upgraded the injectors yet? Once they're done along with a change of turbo you'll need it remapping from what I've read.
Offline mad4vws
Re: vw golf tdi mk3
« Reply #2 on: 22 July 2011, 10:41 »
hi ,not yet doing the gti set up fist to disc all round then the turbo and eventually the injectors than a remap at some point ,already changed the exhaust and air filter. :cool:
BREAKING VW GOLF'S
Offline sharki786
  • GOT BOOST??
Re: vw golf tdi mk3
« Reply #3 on: 09 August 2011, 23:37 »
then you got a chance of getting "AWAY" from me  :tongue:
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: vw golf tdi mk3
« Reply #4 on: 11 August 2011, 13:44 »
Passat turbo wont fit as the housing is wrong (its not a transverse engine liek yours)  and the 115, 130 and 150bhp tdi engines use VNT Turbos, which will be usless.  Your best bet is a good after market turbo,  but then a tdi runs high boost anyway, because it can.   So big injectors and a bleed valve will give you good gains, and to be fair your turbo will run out of puff at 4000rpm+.... but then so does a TDI Engine.   So there is no need for a bigger turbo untill the injectors are upgraded, you have a good intercooler and possibly a remap.  Although this might be best saved till after the bigger turbo if you do decide to get one
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
