Author Topic: mk3 8v temperature sensor  (Read 2069 times)
Offline tianaroja
« on: 11 April 2005, 20:28 »
i am rapidly losing faith with this mk3 i want my mk2 back, my mk3 has been idling at 1500-1800  for months i read the forum and cleaned the deposits off the throttle bodies great for 2 weeks now it is difficult to start from cold , 3 or 4 turns and then you cant move for a minute or it just dies, seems like it needs choke !, logically i thought cold start valve but  reading around it seems temperature sensor is a more common fault , does this description sound like it could be this sensor and if it is how much! any help will be greatly appreciated
Offline Overseer
Re: mk3 8v temperature sensor
« Reply #1 on: 11 April 2005, 20:36 »
check for vacuum leaks too..
Offline tianaroja
« Reply #2 on: 11 April 2005, 20:47 »
yes i was thinking that , i have checked isv valve as well and that wasnt fitted properly thought i had cracked it , the car runs perfect when warm is it the temperature sensor that tells the cold sart valve to work ?if you know what i mean
Offline Overseer
« Reply #3 on: 12 April 2005, 09:56 »
i don't know anything from personal experience about this temp sensor stuff *touch wood*.. but i have read that problems like you're describing can be related to it.. sounds likely esp with the way the problem is related to temp instead of being a more general thing...
i think they're quite cheap arent they?
Offline tianaroja
« Reply #4 on: 12 April 2005, 13:03 »
i will try temp sensor first it may have been causing the fast idle initially and now it is totally knackered worth a try dont want to take it to garage yet sure i can fix
Offline lisa30
« Reply #5 on: 19 April 2005, 20:54 »
My temperature light kept comin on but me temperature level wasnt moving
anyway................today it peed with water hence my radiator is knackered ah
so its away with mr :cry: mechanic tilll tomorrow
[img]http://img.photobucket.com/albums/v714/lisa30/car.jpg
Offline tianaroja
« Reply #6 on: 19 April 2005, 23:46 »
sorted the problem changed sensor which was the wrong color ie green and not yellow and the car runs perfect mpg on the way back from brands hatch on sunday a whopping 45.8 wow
