Author Topic: Head Gasket  (Read 2554 times)
Offline tomp
Head Gasket
« on: 15 July 2011, 20:48 »
Has anyone used an Elring G60 metal head gasket on a mk2 16v?
Just offered the one I bought up to the block on my turbo engine and everything lines up perfectly except for four of the outside channels which aren't quite in line, they are close but not quite there...
Re: Head Gasket
« Reply #1 on: 15 July 2011, 23:42 »
Better to use a 16v gasket, you might block off a water or oil way.
Offline tomp
Re: Head Gasket
« Reply #2 on: 15 July 2011, 23:51 »
I went out and had another look and i think i might get away with it, its only partially covering the four really small outer water ways, everything else is spot on.
Been looking on the net and I think people have used these gaskets on turboed 16v's.
Offline Sam
  • Sam I am
Re: Head Gasket
« Reply #3 on: 16 July 2011, 02:08 »
Even the proper valver gaskets overlap slightly, i wouldnt worry  :smiley:
Offline tomp
Re: Head Gasket
« Reply #4 on: 16 July 2011, 10:32 »
Just spoke to Stealth racing and the G60 head gasket is fine to use, even with the slight overlap! phew  :grin:
Offline danny_p
Re: Head Gasket
« Reply #5 on: 18 July 2011, 19:57 »
the later mls gaskets are the best to use. they are much more durable
i actualy found g60 headgaskets wernt all that good
all the VW's have gone bar 1.
Offline tomp
Re: Head Gasket
« Reply #6 on: 19 July 2011, 22:58 »
Well the head is back on with the G60 gasket so will see what happens I guess!
Offline SoundillusioN
Re: Head Gasket
« Reply #7 on: 20 July 2011, 17:05 »
 :laugh:  :wink:
Offline AudiA8Quattro
Re: Head Gasket
« Reply #8 on: 20 July 2011, 21:38 »
 :grin:
Re: Head Gasket
« Reply #9 on: 20 July 2011, 22:58 »
