Author Topic: remap problem take 2  (Read 2860 times)
Offline MaXXeH
  • Golf MK5 GTI
« on: 15 July 2011, 17:44 »
Well i was meant to go collect my car today,  they said they had loads of boost problems.
Seems the map sensor was the problem  :rolleyes:  When the garage built my car they put the s3 map sensor on and not my golf mk5.
my question is.    Are they really different?  I had to post my old one to them  :rolleyes:  won’t get the car back till Tuesday now  :cry:
can someone look on etka please
Offline Adam
Re: remap problem take 2
« Reply #1 on: 15 July 2011, 19:14 »
One 2bar and one 3bar? :huh: Something sounds fishy!
Down Hill From Here.
Offline MaXXeH
  • Golf MK5 GTI
« Reply #2 on: 15 July 2011, 19:24 »
just downloading  etka 7.3 to find out lol
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 15 July 2011, 20:02 »
yours will be a 2.5 bar sensor 038906051D while the S3 uses 3 bar 038906051C
Offline MaXXeH
  • Golf MK5 GTI
« Reply #4 on: 15 July 2011, 20:16 »
cant u use 3bar one? they siad they cant do anything with it?
Offline topher
  • Administrator
  • fully functioning
« Reply #5 on: 15 July 2011, 20:36 »
no easy solution to that one. Certainly none easier than posting them your original map sensor anyway :smiley:
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #6 on: 15 July 2011, 23:14 »
Sticking with the 2.5bar sensor match to your ecu code is the safe and easy way forward.
The problem is software code with ME ecu its a killer to rescale the boost scale map which converts the 0-5v scale in to hpa and get the code to read over 2.5bar. But if your looking for 330bhp your going to be clipping the map sensor scale, which still can be mapped but means a lot of time dialing in the open loop side of the Boost control and could cause spikes in the winter.  I would have started looking to use an ED30 map structure as a starting point as from past custom tunes reads 3bar pressure. But I have never tried to reverse flash code on tfsi ecus in theory should work and no risk  me7 1.8t are fine with it.
« Last Edit: 15 July 2011, 23:23 by RTechUK »
 01455 617233
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #7 on: 16 July 2011, 16:04 »
We all have days like this but try to remember that good things are worth the wait - at least they are taking their time and doing it right  :wink:
