Author Topic: Bosch Digifant 1.7 ECU pinout diagram wanted  (Read 1189 times)
Offline freezaburn
« on: 15 July 2011, 11:13 »
Golf GTi MK3 2.0l 8V 1994
I *desperately* require a pinout diagram for a Bosch Digifant v1.x 68-PIN ECU
In particular which ECU pins must be earthed?
Which pins need power when ignition is ON?
Which pins need power when igntion is OFF (if applicable).
Reason: ECU keeps setting CO2 to a reading of "160" instead of "128" everytime the battery is disconnected. (i.e I can use my petrol needle as a rev counter)  :sad:
I have already had the ECU tested by professionals and it has come back 100%
