Author Topic: Disable Rear window  (Read 1593 times)
Offline djalexr
Disable Rear window
« on: 14 July 2011, 13:21 »
Hi Everyone,
Normally the buttons for one of the rear windows are unresponsive...(the ones on the dash and on the door of the window itself)
However someone sitting in the back once randomly managed to get open it, after which it would not shut...after a while it did go back up again...
I want to know the quickest/best way of disabling that window to avoid any possibility of the irritating situation where the window is stuck open.
Also, any tips on what to do if the window does get stuck open would be helpful!!
Thanks a lot,
Alex
Offline Luke1981
Re: Disable Rear window
« Reply #1 on: 14 July 2011, 16:15 »
Take the door card off and disconnect the pin connector that feeds the window motor. It unclips and slides off.
Its a pain in the arse trying to replace the door mechanism for a new one if the window wont come down.
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline javalin
« Reply #2 on: 20 July 2011, 15:57 »
easier - just take the handle off and un-plug the window switch connector.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline VR6_Wherry
« Reply #3 on: 20 July 2011, 16:13 »
What this man said. That's what i did till i got round to replacing it :)
Offline mellow yellow
  • A Driffield Dubber!
« Reply #4 on: 20 July 2011, 16:38 »
or just press the locking button in the centre of the dash, for child safety i believe. always have mine like this because my kids are always pratting around with the buttons in the back.
Offline djalexr
« Reply #5 on: 20 July 2011, 18:00 »
all good advice, thanks :)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #6 on: 20 July 2011, 22:59 »
This
Offline vdubnut
« Reply #7 on: 25 July 2011, 08:55 »
odd side q to this.... on mine the switch on the handle works fine but the one on the dash doesnt for the drivers side rear but does for the passenger rear....any ideas? (all the windows open and close on the key though!)
Offline dansmk3
  • FULL TIME JUNGLIST
« Reply #8 on: 25 July 2011, 09:00 »
bad connection on the switch in the dash?? check the connnection
Offline vdubnut
« Reply #9 on: 25 July 2011, 11:46 »
tried a new switch and still same :( ITS odd as one side of the switch works fine but other side doesnt...
