Author Topic: mk3 gti 8v/vr6 help!!!  (Read 1424 times)
Offline NERF 69
« on: 13 July 2011, 22:12 »
Hi all new blood here ive just registered. Had my golf for 2 months now and just been offered a 3.1ltr vr6 engine and gear box. Does anyone know if anything needs modifing to fit it? Or is it a "simple" drop in and bolt on?
Sell my Vw??? I'd rather stick wasps up my arse
Offline benvictors
  • bgk Tuning - coming soon!!!
Re: mk3 gti 8v/vr6 help!!!
« Reply #1 on: 13 July 2011, 22:39 »
Should be in the MK3 section but as your here  :wink:
Aswell as the engine and box you will need
The engine Loom
The Ecu
The hydro clutch set-up (if yours is an early 8v the full pedal box out of a later spec mk3)
The cable change gear linkage.
New engine mounts
Twin rad fans
Clocks
Thinks thats about it  :shocked: :shocked:
« Reply #2 on: 13 July 2011, 23:05 »
3.1 are you sure. :smiley:
Offline NERF 69
« Reply #3 on: 13 July 2011, 23:54 »
Got all the above. Does it just drop straight in? And yes deffinately a 3.1 its not quite standard
« Reply #4 on: 13 July 2011, 23:55 »
What crank is it running etc or what spec is it.
Offline NERF 69
« Reply #5 on: 14 July 2011, 00:04 »
Exuse me for being uneducated but its my first golf on im not quiet sure of all the ins and outs of it yet
Offline dom
  • Back in a Mk4
« Reply #6 on: 14 July 2011, 06:20 »
It'd be worth finding out exactly what work has been done to the engine, if it is 3.1l then it is far from standard & it'd be a good idea to check everything has been done properly :wink:
Offline tweed
« Reply #7 on: 14 July 2011, 16:21 »
sounds like a vr6 engine. you will need a vr6 subframe too
Offline dom
  • Back in a Mk4
« Reply #8 on: 14 July 2011, 23:06 »
What gave it away? :grin:
