Author Topic: mk1 golf speedo clocks  (Read 6179 times)
Offline travisreeve
« on: 13 July 2011, 21:59 »
im woundering if i can put the set of clocks in my mk1 golf with the rev counter built into them asfor the set i took out had a clock i would like to do this asfor i am now running a 1.8 20vt is it as simple as just swapping clocks over
Offline raferackstraw
Re: mk1 golf speedo clocks
« Reply #1 on: 13 July 2011, 22:17 »
there is a couple of threads on here with wiring for the mk1 clocks to mk2 clocks that show what wires do what, you maybe able to use that to help you rj gives some useful links
http://www.golfgtiforum.co.uk/index.php?topic=70697.0
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline SoundillusioN
« Reply #2 on: 14 July 2011, 12:08 »
I didn't even understand that!  :grin:
I get what clocks yours had, sh*t ones, are you looking to put MK1 GTI clocks in and make them work with your engine?
Offline jimbo198966
« Reply #3 on: 17 July 2011, 17:55 »
mk1 gti clocks (with the rpm counter) is a straight swap. just connect the red/black wire in the engine bay to your coil (or what ever produces the signal for the tach.)
« Reply #4 on: 18 July 2011, 11:28 »
Not sure how straightforward that is considering it's a 20vt???
Offline jimbo198966
« Reply #5 on: 18 July 2011, 19:03 »
depends how the signal for the tach is produced on the 20vt (which i;'ve no idea, i'm guessing its not a coil  :grin: )
