Golf mk3
hardmonkeys
B and C pillars
Topic: B and C pillars (Read 2016 times)
tdi_blu
Golf Gti & T4 2.5 tdi
B and C pillars
13 July 2011, 17:26 »
Just bought some colour concept A,B,C pillars for my anni Ive found a guide on removing the headlining which involves unclipping the abc pillars etc but whats the best way of actually removing the b and c pillars due to the seat belts going through them?Sorry if its been asked just couldnt find much info on it.
Golf Gti
F17BAD
Forum addict
Golf MTM S3 GTI TURBO
Re: B and C pillars
13 July 2011, 17:42 »
basically its a pain in the ass boring job
gotta remove all lower plastics on front and unbolt the seatbelts if memory is correct (i could be mistaken as its years since i did mine) either way its not hard
rears your have to remove all platics in boot and the carpet on the sides, and the supports for the parcel tray
it will take you about a hour to do it all
Not no ordinary GTI....
www.mixcloud.com/kells/
mad4vws
Re: B and C pillars
13 July 2011, 18:12 »
hi blue ,it's real easy mate doing some on my mate sharki as he also has changed his a b & see pillars and has relined his roof lining also put some lights in the roof lining ,hopefully he will post some pic's soon on the site,if you need a hand let me know?.
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!! ON 07813936583
benvictors
bgk Tuning - coming soon!!!
Re: B and C pillars
13 July 2011, 18:16 »
Pretty much what Brad said, remove rear door cards
Remove parcel shelf and supports
Remove rear bench (makes life a lot easier) Remove the inside sill trims
remove the bolts holding the seatbelts to the car
You can now pull the B pillars off and you will be greated by 2 screws, un-do screws. Go to the boot and look on the bottom of the C pillars, there are 3 plastic nuts, remove these
You are now ready to remove the A and C pillars
tdi_blu
Re: B and C pillars
13 July 2011, 19:54 »
Thanks for the replys I havent got them as yet but thought I would ask before I attempted it
I was thinking of doing my headlining some shade of red I reakon it will look nice with the black pillars anyway thanks again for the replys
Golf Gti
Len
10k hero
Re: B and C pillars
14 July 2011, 08:59 »
Why not paint the pillars and use spray glue on the headlining?
www.sas.org.uk
www.the-ace.org.uk
chiefwhosm
GTI forum regular
Re: B and C pillars
Reply #6 on:
14 July 2011, 20:50 »
http://www.diynexus.com/vw/mk3_remove_headliner/mk3_remove_headliner.html
Was it that ^ guide? If so it's the one I followed. Main issue I had was the A pillars trying to break (I personally will have to use some glue now when the car goes back together), but the others were okay for the most part following how the guide tells you to remove them.
C pillars mind, that took a lot of rocking and violence because of the big metal clips that are keeping the panels on but were very firmly connected.
That guide also doesn't mention the C pillars have little square-ish nuts under the parcel shelf supports that need removing (think it's 3 per side).
Also don't be foolish like me and not realise that you just take the headling out through the boot and not try and bend it out of the side doors
Chief
sharki786
GOT BOOST??
Re: B and C pillars
Reply #7 on:
14 July 2011, 21:07 »
i did mine yesterday got help from my cousine (asif) and Abdul. did the headline purple velvet (will upload pics soon on my project)black ABC pillars, grab handles & sunvisors. i also drilled the plastic bit out that covers the sunroof & sprayed it matt black. Also did the sunroof motor colour matt black (came out reealy good).
blu whatever you do alow PLENTY of time.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Golf mk3
hardmonkeys
B and C pillars
