Author Topic: mk5 ecu wanted,,,,,,  (Read 2896 times)
Offline candywhitefudd
« on: 13 July 2011, 12:51 »
in need of a mk5 gti ecu 54,,2005 . any1 help pls part no... 0 261  s02 078 bosch thanks
Offline The Doc
  • E63s Estate - Vito Sport
Re: mk5 ecu wanted,,,,,,
« Reply #1 on: 13 July 2011, 14:52 »
What is / are the faults that make you think it's broken?
Offline _Adam_
« Reply #2 on: 13 July 2011, 16:25 »
 :grin:
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #3 on: 13 July 2011, 21:23 »
Sandburns in Coventry may have one in stock, you will need to quote the full number ending in 115xx If you need the ecu pairing up with you vin and immo info let me know as we extract the content from the EEPROM on you duff ecu,
 01455 617233
« Reply #4 on: 15 July 2011, 22:27 »
thanks for the replys.the mechanic said the main egnition relays have lost the switching feeds.if you manually power the switching feed it fires the relays and the car wheele one.the switching feeds come from the ecu according to the wireing diagram but are totally dead.all fuses and earths are fine.
Offline The Doc
« Reply #5 on: 15 July 2011, 22:50 »
Ok.
You could try these guys: http://www.bba-reman.com/uk/index.aspx
Best of luck with it - let us know how you get on and watch those knuckles  :wink:
